LETSHUOER S08 In-Ear Monitors Black
The Letshuoer S08 in-ear monitors are planar magnetic IEMs. They feature a high-quality design with a custom 13mm-diameter planar magnetic diaphragm and dual voice coils. The brand has used advanced processes in the manufacture of the S08, such as nanoscopic magnetron sputtering on the diaphragm, allowing the addition of an extra coil compared with the majority of headphones. The result is better control of diaphragm vibration, reducing resonant frequencies and distortion, and improving the transient response of the S08.
Reference : 19870
89,90 €tax incl.
74,92 € tax excl.
Letshuoer S08 Fourth Generation In-ear monitor IEM Planar Magnetic 26Ω 105dB 20Hz-40kHz Black
Photo of Letshuoer S08 Fourth Generation
The Letshuoer S08 in-ear monitors are planar magnetic IEMs. They feature a high-quality design with a custom 13mm-diameter planar magnetic diaphragm and dual voice coils. The brand has used advanced processes in the manufacture of the S08, such as nanoscopic magnetron sputtering on the diaphragm, allowing the addition of an extra coil compared with the majority of headphones. The result is better control of diaphragm vibration, reducing resonant frequencies and distortion, and improving the transient response of the S08. In addition, the addition of an elastic film provides greater diaphragm flexibility and stability for deeper, tighter bass. The S08's 26 ohm impedance and 105dB sensitivity make them easy to drive. A detachable audiophile cable with silver-plated copper conductors and interchangeable 3.5 mm jack to 4.4 mm balanced jack termination completes the package.
Letshuoer S08 Fourth Generation exploded view
Letshuoer S08: innovative IEMs
The customized diaphragm structure of the fourth-generation S08s offers a balanced sound across their frequency range and improved diaphragm control for lower distortion.
Letshuoer S08 fourth-generation structure
The key benefits of S08 IEMs
Nanoscopic magnetron spraying
This high-end production technique offers superior durability and sound performance.
Dual coil
Dual voice coil
The dual-coil design offers better diaphragm control for faster transient response.
Letshuoer S08 Fourth Generation elastic film
Elastic film
The addition of PTR elastic film on the edges of the diaphragm coils for greater flexibility and stability greatly enhances low-frequency reproduction.
Letshuoer S08 Fourth Generation cable
Letshuoer S08: an audiophile cable
The S08s have 0.78mm CIEM connectors and are therefore compatible with a wide range of cables. However, a high-quality detachable cable is already supplied with the S08. This cable has 4 multi-stranded conductors, each with 30 strands of 0.05mm silver-plated copper, for stable, reliable transmission of the audio signal. What's more, an interchangeable 3.5mm unbalanced / 4.4mm balanced jack termination means that the S08 can be used with the majority of equipment available on the market.
Letshuoer S08: a modern look
The shell of the fourth-generation Letshuoer S08 is made of CNC-machined aluminium for high impact resistance and durability. Another striking feature is the slim, modern design representing their name, S08, integrated into each earpiece.
The Letshuoer S08 Fourth Generation appearance
Product typeIn-ear monitors
Speakers typeMagnetic planar diaphragm with dual voice coil
Diaphragme diameterØ13mm
Shell materialCNC-machined aluminum
Impedance26Ω
Sensitivity105dB
Frequency response20Hz-40kHz
CIEM connectorsCIEM 0.78mm
Cable terminaisonInterchangeable: 3.5mm jack/4.4mm balanced jack
Cable conductors4x 30x0.05mm silver-plated copper strands
Package1x Letshuoer S08 in-ear monitors
1x CIEM 0.76mm detachable cable to interchangeable termination
1x 3.5mm jack termination
1x Balanced 4.4mm jack termination
5x Pair of ear tips
Impedance (Ω)26
Efficiency / Sensitivity (dB)105.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
Superbe
Très bon Iem. J'aime la sonorité des membranes "planaires". Dans tous les cas : panneaux, casques, ou intras. D'aucun se plaignent d'un manque de grave et d'infra grave... ce n'est pas le cas ici. C'est petit bijou dédié aux mélomanes nomades et il est magnifiquement dessiné et la finition est parfaite.
J'aime bien...
This review has been posted for LETSHUOER S08 In-Ear Monitors IEM Planar Magnetic 26Ω 105dB 20Hz-40kHz Black
The Letshuoer S08 in-ear monitors are planar magnetic IEMs. They feature a high-quality design with a custom 13mm-diameter planar magnetic...
