Très bonne qualité d'écoute au départ, extraordinaire avec quelques égalisations (j'ai acheté depuis le cable/dac usb moondrp qui permet de le faire);
In-Ear Monitors IEM Dynamic 10mm 119dB 18 Ohm 15Hz-38kHz
Moondrop updates its CHU earphones to version II. Still benefiting from a high-quality design and sound reproduction, the price remains very affordable. Each IEM (In-Ear Monitor) houses a 10mm diameter dynamic driver with a composite membrane coated in Nano-Crystal, placed in an acoustically optimized cavity. These drivers are powered by a motor using an N52 neodymium magnet and an ultra-thin CCAW coil (0.03mm), ensuring excellent efficiency and providing sound reproduction that is both dynamic and rich in details, while staying true to the original signal.
Sturdy, these Chu II earphones have a beautifully crafted metal body. The ear tips are designed to eliminate undesirable resonances, significantly reducing linear distortion of high frequencies and promoting a natural timbre, all while offering a very comfortable fit, perfectly adapting to the shape of the ear.
"The Moondrop Chu II offer very good response with very low distortion. A little equalization enhances their performance, producing an astonishing level of fidelity on any well-recorded piece of music. Their weight and small size make them comfortable to use. And their sober look is pleasing."
| Specifications | |
| Product type | In-Ear Monitors (IEM) |
| Driver type | Dynamic 10mm |
| Diaphragm | Composite, titanium-coated |
| Magnet | Neodymium N52 |
| Voice coil | CCAW 0.03mm |
| Body material | Zinc alloy |
| Sensitivity | 119dB/Vrms @ 1kHz |
| Impedance | 18Ω ±15% @ 1kHz |
| THD | ≤ 0.5% @ 1kHz / 94dB |
| Effective frequency response | 15Hz - 38kHz (IEC60318-4, -3dB) |
| Earphone connector | CIEM 0.78mm |
| Cable connector | Jack 3.5mm |
| Package | 1x CHU II earphones 1x Detachable cable 0.78mm to Jack 3.5mm 3x Pair of ear-tips (S / M / L) 1x Storage bag |
| Color | Black |
| Impedance (Ω) | 18 |
| Efficiency / Sensitivity (dB) | 119 |
| Lowest frequency (Hz) | 15 |
| Highest frequency (Hz) | 38000 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | CIEM |
| Phone call feature | No |
| Noise reduction | No |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
luc M.
Elom G.
CLAUDIO R.
