TANCHJIM MINO In-Ear Monitors Wireless Black
The Tanchjim Mino are high-performance, affordable Bluetooth wireless in-ear monitors. Each earphone features a 10mm dynamic driver for rich, lively sound reproduction. The earphones come with a charging case for extended battery life and easy transport. What's more, the Tanchjim Mino feature effective Active Noise Cancellation (ANC) technology.
Reference : 20578
49,00 €tax incl.
40,84 € tax excl.
Shipping date: 25-06-2025.
Tanchjim Mino In-Ear Monitors TWS Wireless Bluetooth 5.3 ANC Black
Tanchjim Mino picture
Tanchjim Mino: key features
Tanchjim Mino: Highly effective active noise-cancellation technology
Tanchjim Mino earphones feature active noise cancellation (ANC) technology based on deep learning, enabling noise reduction down to -45dB. As a result, the majority of surrounding noise can be eliminated by activating this feature, for perfect immersion in your music.
Tanchjim Mino: Active Noise Cancellation (ANC) graphics
Tanchjim Mino: Dynamic drivers
Tanchjim Mino: 10mm dynamic drivers
The Tanchjim Mino feature a dynamic 10mm driver using a powerful magnetic circuit. Each driver is equipped with a beryllium-plated dome and PU suspension to extend the headphones' dynamic range, while greatly reducing distortion (non-linear distortion below 0.1%) and promoting a defined soundstage.
Tanchjim Mino: Transparency mode
By activating the Transparency mode of the Tanchjim Mino earphones, you can enjoy your music while remaining aware of your surroundings. Ideal when you're on the move and need to keep an eye on the outside world.
Tanchjim Mino: Perfectly tuned sound
The Tanchjim Mino are professionally tuned for detailed highs, smooth mids and immersive lows to match the brand's defined response curve.
Tanchjim Mino: frequency response curve
Tanchjim Mino: Noise cancellation for calls (ENC)
One of the Tanchjim Mino earphones features a dual microphone for sound filtering. It also incorporates a wind detection system. So you can make calls and enjoy crystal-clear exchanges with the person you're talking to, thanks to ENC ambient noise cancellation technology.
Tanchjim Mino: Extended autonomy
With the noise-cancellation mode activated, each earphone has a comfortable battery life of 5 hours per charge. Added to this is the charging box, which recharges the Tanchjim Mino for up to 31 hours. In Normal listening mode, this autonomy increases to 6h per earphone, and is extended to 37h with the charging box.
Tanchjim Mino: Consistent battery life
Tanchjim Mino: Automatic connection
Tanchjim Mino: Automatic, instant connection
Thanks to the integrated magnetic switch, Tanchjim Mino headphones automatically reconnect to your previously paired smartphone or source device as soon as the case cover is opened.
Tanchjim Mino: Control app
Tanchjim provides a free mobile app to access additional functions, including sound profiles, equalizer, touch control management and more. This app is available on Android via an apk or downloadable for iOS devices directly from the App Store.
Tanchjim Mino: Faultless responsiveness
With a delay of just 0.045 seconds, the Tanchjim Mino are particularly responsive. So they're also ideal for gamers requiring latency-free sound.
Tanchjim Mino: Waterproof and dustproof
Thanks to their IPX4 rating, Tanchjim Mino earphones are waterproof and dustproof. So you can use them even on a rainy day, without risk of damage.
Make sure the earphones are dry when stored in the charging box.
Tanchjim Mino: IPX4 standard
Tanchjim Mino: Bluetooth 5.3
Bluetooth version 5.3 ensures a fast, stable connection, thanks in particular to optimized anti-interference technology.
Tanchjim Mino: Touch controls
Tancjim Mino features an intelligent touch control system. So you can control your music playback or answer a call simply by touching your earphones:
  • Single press: Play / Pause / Answer a call
  • Double press: Previous track (left earphone) / Next track (right earphone) / Hang up
  • Triple press: activate the paired smartphone's voice assistant
  • Press and hold 2s : Activate or deactivate noise cancellation (left earphone) / Activate or deactivate transparency mode (right earphone)
  • Press twice and hold for 5s: Re-pair a device
Tanchjim Mino: Automatic playback
Tanchjim Mino: Automatic playback of your music
Thanks to a capacitive sensor on the earpieces, your music stops automatically when an earpiece is removed from your ear. Likewise, playback resumes automatically as soon as the earpiece is reinserted in your ear.
Product typeIn-ear monitors
Connection modeBluetooth 5.3
Max range15m
DriversDynamic Ø10mm
Drivers materialsBeryllium-coated dome
PU surround
Impedance32Ω ±10% @ 1kHz
Wired charging interfaceUSB-C
Wired charge voltage / current5V 1A
Codecs Bluetooth supportésAAC, SBC
Battery life5h + 26h
Battery capacityEarphones: 35mAh 3.7V 0.129Wh
Charging case: 380mAh 3.7V 1.406Wh
Package1x Tanchjim Mino earphones pair
1x Charging case
1x Charging cable
3x Eartips pairs (S/M/L)
Impedance (Ω)32
WirelessYes
Cable terminationWireless
Headphone / Earphone connectorWireless (Bluetooth)
Phone call featureYes
Noise reductionYes
TANCHJIM MINO In-Ear Monitors TWS Wireless Bluetooth 5.3 ANC Black
The Tanchjim Mino are high-performance, affordable Bluetooth wireless in-ear monitors. Each earphone features a 10mm dynamic driver for rich,...
