By buying this product you get 95 loyalty points
Thieaudio Origin in-ear monitors are high-end earphones featuring a Quabrid 1DD + 4BA + 2EST + 1BC design per monitor, for a total of 16 drivers. Thieaudio, in addition to its meticulous design, gives the IEM Origin the benefit of its fine expertise, with settings for an immersive audio experience. The IEM Origin are specially designed for bass lovers, yet remain balanced across their entire sound spectrum, with accurate midrange and natural extended highs. Their 9 ohm impedance and 102dB sensitivity make them easy to drive. In addition, the electrostatic drivers deliver rich highs with an extended frequency response of 20Hz-44kHz. A detachable 0.78mm CIEM audiophile cable with interchangeable 3.5mm jack, 2.5mm jack and balanced 4.4mm jack terminations completes the package.
The Thieaudio Origin features a set of 4 driver types per earphone, promising textured sound reproduction. Indeed, two electrostatic drivers act as super-tweeter, two Knowles TWFk-30017 take care of the treble, two full-range Sonion 2600 take care of the midrange, while a Ø10mm bio-cellulose dynamic driver offers immersive bass. The internal 11mm Bone Driver (BC) adds texture to the midrange and treble.
Specially designed for bass enthusiasts, Thieaudio Origin features the most committed bass signature in the Thieaudio catalog. With 12dB of sub-bass precisely cut at 250kHz. However, despite this emphasis on bass, the final result remains balanced thanks to Thieaudio's fine-tuning. This configuration offers what many users are looking for: very present bass and highly detailed mids and highs for a perfect tonal signature.
Tuned to target the midrange and treble, the BC driver greatly enhances the listening experience with Thieaudio Origin. Thanks to its tactile vibrations, it adds a new dimension to sound rendering, resulting in a wider soundstage.
A detachable 0.78mm to interchangeable termination cable allows the user to choose between 3.5mm jack, 2.5mm jack or balanced 4.4mm jack terminations for use with a wide range of devices. This cable features high-quality components, including a silver-plated LCOFC 5N 7x7x0.08mm wire and a silver-plated LCOFC 4N 16x7x0.06mm wire. With a cross-section of 20AWG, it ensures optimum signal transmission. In addition, the cable incorporates spiral shielding and Litz Type 2 technology for greater durability and reduced signal loss.
Product type | In-ear monitors |
Drivers | 1x Dynamic driver 2x Electrostatic Sonion 2x Knowles TWFk-30017 2x Sonion 2600 1x BC (Bone conductor) |
Frequency response | 20Hz-44kHz |
Sensibility | 102dB (±1dB) @ 1kHz |
Impedance | 9Ω @ 1kHz |
Cable type | Detachable |
Earphone connectors | CIEM 0.78mm |
Cable terminaison | Interchangeable |
Package | 1x Thieaudio Origin Quadbrid earphones pair 1x 0.78mm CIEM cable to interchangeable termination 1x Jack 3.5mm termination 1x Termination Jack 2.5mm 1x Termination Jack 4.4mm balanced |
Color | Black |
Color | Blue |
Impedance (Ω) | 9 |
Efficiency / Sensitivity (dB) | 102.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
Wireless | No |
Cable termination | Jack 2.5mm |
Cable termination | Jack 4.4mm |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
