AUDIOPHONICS SUB Subwoofer Amplifier Class D TPA3116 100W 4 Ohm
AUDIOPHONICS SUB Subwoofer Amplifier Class D TPA3116 1x50W 8 Ohm
This compact Audiophonics SUB subwoofer amplifier will allow you to power a subwoofer with 100W under 4Ω. It includes a high efficiency Class D TPA3116 amplifier chip and a low pass filter based on an AOP NE5532P. The input is done in 3.5mm jack and the output on speaker terminals.
4.7 / 5
Reference : 16623
29,90 €tax incl.
24,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
Audiophonics SUB
Audiophonics SUB Amplificateur Subwoofer Class D TPA3116 100W 4Ω
Product typeSubwoofer amplifier
Input1x Jack 3.5mm
OutputSpeaker terminals
Amplification typeClass D
Amplification chipTPA3116
OPANE5532
Frequency response20Hz - 80Hz
Output power100W @ 4Ω
Supply voltage12-24VDC (alimentation vendue séparément)
Housing materialAluminum
Dimensions69 x 88 x 33mm
Weight220g
InputJack 3.5mm
Channel1 (Mono)
Amplifier chipTPA3116
Power (W)100.0
3 reviews
Surprisingly powerfull
The build in amplifier of my old Monitor Audio Radius 360 subwoofer died. In stead I connected the driver unit directly to this little amplifier. (so I used the sub as a passive subwoofer). Powered by a 6 ampere 24V SMPS:
Surprise: bass sounded deeper, less boomy/muddled and more powerfull than with the original build in amplifier of the subwoofer!
Thanks to audiphonics.
This review has been posted for AUDIOPHONICS SUB Subwoofer Amplifier Class D TPA3116 100W 4 Ohm
ampli sub
Petit mais costaud ! Bon renfort de basses nettes et pas ”boursouflées” . Super rapport qualité prix
So far so good!
I bought this to use with a 10" passive DIY sub as part of my "desktop" setup. And it seems to get the job done admirably in spite of its low price and diminutive size. I can't really say anything about its max power though, since this is very nearfield listening at low to moderate volumes. Even the power supply I use is only 12V 5A, since I had an extra laying around. More than enough for this use case in any case.
One minor minus is that turning the volume pot functions as the on/off for the device, which is a hassle when you want to keep it at a preset level but would still like to turn it off. Also it has quite a bit of "play" before it actually turns the thing on/off, and doesn't really feel that great to turn.
One other thing to note is that this indeed takes a 3.5mm stereo plug and combines the channels for output. The 60W subwoofer amp stated that, while this one didn't.
All in all a handy device well worth its price for smaller-scale applications.
This compact Audiophonics SUB subwoofer amplifier will allow you to power a subwoofer with 100W under 4Ω. It includes a high efficiency...
