FX-AUDIO FX502SPRO Amplificateur Class D TPA3250 2x 80W 4 Ohm Black
FX-AUDIO FX502SPRO Amplificateur Class D TPA3250 2x 80W 4 Ohm Noir
The FX502SPRO is a high-performance Class D amplifier capable of powering a pair of speakers up to 80W (4ohm) or 50W (8ohm)
4.3 / 5
Reference : 12626
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Amplifier FX502SPRO by FX-AUDIO
amplifier classe D TPA3250 FX502SPRO
The FX502SPRO is a high performance Class D amplifier capable of powering a pair of speakers up to 80W (4ohm) or 50W (8ohm)
It exploits the amplification chip TPA3250 - worthy successor of the TPA3116. With a design incorporating a wide range of safety (anti overheating, clipping, short circuits) the TP3250 amplifier is natively equipped for longevity. This is an excellent level of class D that enjoy excellent performance and responsiveness to bring all the power needed for your speakers while maintaining a minimum level of distortion.
The circuit uses two interchangeable OP Amp NE5532. A property that will delight DIY enthusiasts and those who want to customize the rendering and modulate components with ease.
The circuit is equipped with a high-speed error correction driver that boosts the power while still in the noise to a near-zero level. The volume knob is at zero, no noise is noticeable and in its original state, no noticeable distortion is noticeable unless OCT.
Original point, the volume knob is slightly notched at its potentiometer. It is also possible to locate and find its ideal listening volume while enjoying the finesse of setting a fully accessible potentiometer.
Great performance and compact design
back of FX502SPRO case RCA input & speaker output
The Class D FX502SPRO amplifier is protected by an elegant black aluminum case. The entire device is relatively thin given its performance and can be easily integrated even in systems already cluttered. All the connectivity is located at the back of the case so as to remain very accessible while limiting the maximum space occupation so as not to congest your audio installation.
SPeCIFICATIONS
Output Power2 x 80W (4 Ω) / 2x50 W (8 Ω)
2 x 65W 4 Ohm @ 1% @ 24V
2 x 32W 8 Ohm @ 1% @ 24V
OutputEnceintes R + L
Speaker Impedance 4 - 8 Ω
Power Supply (included)24V 4A
SNR84 dB
ControlsFront face power / volume
THD0.1%(+/-0.2dB)
Weight1.2 kg
Dimension155 x 90 x 40 mm
Amplifier chipTPA 3250
CaseAluminium, PCB
Package content
1 xAmplifer F502SPRO
1 xPower Supply 24V 4A
1 xUser Manual
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3250
Power (W)50.0
6 reviews
après rodage !
J'étais un peu déçu par l'agressivité au départ (voir avis précédent), mais après quelques heures, c'est beaucoup moins fatiguant ! Je me suis peut-être habitué, je pense surtout que quelques heures de rodages lui ont fait du bien, du coup, je suis content !
à choisir entre un ampli habituel dans les 300€ ou ça 5xmoins cher, si on a pas besoin de toutes les options il n'y a pas à hésiter !
This review has been posted for FX-AUDIO FX502SPRO Amplifier Class D TPA3250 2x 65W 4 Ohm Black
efficace, mais un rien agressif
J'ai acheté cet ampli pour remplacer un vieux machin hifi que j'avais acheté en brocante et qui m'a laché.
J'écoute souvent de la musique, je ne pense pas pouvoir me qualifier d'"audiophile", mais je suis mélomane, musicien, et j'écoute tres souvent de la musique, avec un esprit critique tout de même. au niveau du matériel, je n'ai simplement pas encore investi dans des articles de luxe.
J'écoute donc ma musique sur des anceintes colonne de bonne facture (un hasard des brocantes aussi), mais j'ai jusqu'à présent été frustré de la dynamique, particulièrement dans le registre grave, en les testant avec les 3 différents ampli -hifi que j'avais à la maison (genre 300€ neuf, amplis de grandes marques habituelles). Avec le FX50, aucun doute, ça envoie, il va fort, et même à volume contenu on sent les coups de grosse caisse, c'est tout ce qui me manquait ! Si j'ai bien compris la classe D donne ces résultats en général. Sans pour autant devenir oppressant, c'est assez aéré, et j'ai entendu plus de détails qu'avec mes autres amplis. Donc c'est plutot bien.
Par contre c'est agressif aussi sur le reste du spectre. avec la musique que j'écoute ( un peu de tout mais particulièrement du rock et du métal progressif), ça devient vite fatiguant. Je n'ai pas eu cette impression sur d'autres enceintes bibliotheque, certainement de moins bonne qualité, avec lesquelles le rendu est très sympa.
Je vais très probablement garder le FX50 pour amplifier les graves de mes colonnes, et utiliser un autre ampli plus "doux" pour les médiums et aigues (les colonnes sont bi-amplifiables). J'ai commandé le MOS 120 d'audiophonics. En classe A/B cette fois-ci, et qui reçoit de bonnes critiques... On verra, et je vais essayer de donner un retours après...
En gros, pour le FX50 : Super, pas cher, puissant, détaillé, dynamique, mais pas pour une écoute trop fine (je ne sais pas comment le dire, mais à mon avis avec des baffles de la même game de prix le résultat doit être vraiment bon)
Good for Money
Good amp. Swapped the opamps to OPA2134.
The original opamps are probably fake. At least they look
different from real Texas Instruments NE5532
(the logo is smaller).
une bonne expérience mais...
La découverte de cette ampli aura été une bonne expérience. Cette nouvelle génération d'amplis est un phénomène sympa.
Après plusieurs semaines d'utilisation, il m'a fallu quand même déchanter. Ma configuration n'était peut-être pas idéale: utilisation pour sonoriser la télé devant un DAC. Mais quand même: outre la manque de praticité (pas de télécommande), j'ai rencontré des problèmes de sibilance et de distorsion occasionnelle. Et un jour je suis tombé sur les mesures, catastrophiques, de cet ampli effectuées par le site Audio Science Review. Je suis repassé à mon ampli stéréo de classe AB traditionnel qui tenait le rôle du FX-Audio auparavant, et tous les désagréments ont disparu. L'ampli traditionnel était en fait bien meilleur. Ce n'est qu'à volume très faible (écoute de minuit) que la technologie class D semble apporter un peu plus de clarté; mais pour les écoutes de minuit, mon ampli stéréo dispose d'une prise casque! Autre avantage peut-être, le format de poche.
J'aime beaucoup Audiophonics, leur DAC AK4495, par exemple, est exceptionnel, mais quand même, des mentions dans la description comme "équipé pour la longévité" ou "niveau de distorsion minimal" interrogent un peu. Comme il existe très peu d'amplis avec le TPA3250 sur le marché, il y aurait un créneau pour Audiophonics pour en proposer une mise en oeuvre plus convaincante.
Alors c'est vrai ce n'est pas très cher, et c'est sympa d'expérimenter; mais pour le double du prix ou même moins, en cherchant un peu, on a un ampli standard de grande marque en occasion ou en promo, avec télécommande, plusieurs entrées et prise casque. Pour ma part j'ai fini, vu mon utilisation, par prendre un ampli home cinema, pour un prix très raisonnable, avec pléthore de fonctions, et la correction acoustique en prime.
Very good amplifi
I am very satisfied with the part.
Both chips have been swapped and the music has become even better.
Everything went well with the delivery ...
Can only agree with what has already been written
