3E AUDIO A7 Amplifier
3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A7 amplifier is based on two TI TPA3255 chips in PBTL configuration, and two dual OPA1612A OPAs. This means it can deliver up to 2x 250W into 4 ohm power.
4.5 / 5
By buying this product you get 37 loyalty points
Reference : 20372
379,00 €tax incl.
315,83 € tax excl.
3E Audio A7 Class D Stereo Amplifier PBTL 2xTPA3255 2x250W 4 ohm
Photo of 3E Audio A7
In terms of connectors, the 3E Audio A7 features an RCA input, a practical balanced XLR/Jack 6.35mm combo input, and an output on speaker terminals. The RCA inputg gain can be adjusted (LOW=25dB, HIGH=28.5dB), and the preamplifier stage and volume control can be bypassed for use as a power amplifier. Versatile and high-performance, this little amplifier is able to offer a good reserve of power while preserving the final sound reproduction.
Product update
In response to feedback from the Audio Science Review community, 3E Audio has made a number of modifications to its amplifiers.
  • Auto power off time set to 20 mins.
  • Increase audio detection sensitivity RCA: 200uVrms; XLR: 400uVrms,this significantly meet some user listening in very very low volume.
  • Auto audio sensing power on/off can be disable/enable by user. To do so, simply press and hold the 5 seconds volume button in standby mode, and the RCA LED will flash for 3 seconds to deactivate it. To reactivate, follow the same procedure, but the XLR LED flashes for 3 seconds.
A7
A7se
A7 Mono
A5se
A5
Amplification chip
2x TPA3255
2ch - PBTL
1x TPA3255
2ch - BTL
1x TPA3255
1ch - PBTL
1x TPA3251
2ch - BTL
2x TPA3251
2ch - PBTL
Output power
(4 ohm, THD+N=1%)
2x 250W
2x 230W
1x 260W
2x 140W
2x 150W
Output power
(8 ohm, THD+N=1%)
2x 140W
2x 130
1x 150
2x 70W
2x 80W
Load impedance
2-16 ohm
4-16 ohm
2-16 ohm
4-16 ohm
2-16 ohm
3E Audio A7: Two TPA3255 chips
The two TPA3255 amplifier chips offer a consistent level of output power, as the 3E Audio A7 delivers up to 2x250W into 4 ohm and up to 2x140W into 8 ohm (THD+N = 1%). In addition, the PBTL configuration maintains continuous, stable output power while reducing power losses. It also enables the amplifier to withstand loads of up to 2 ohms.
TPA3255 chips
Interchangeable DIP8 OPAs
3E Audio A7: Interchangeable OPAs
The preamplifier stage of the 3E Audio A7 is made up of two double OPA1612A OPAs mounted in DIP 8 and easily replaceable with pliers, thanks to the design of the case. In fact, the OPAs can be accessed through two hatches without opening the case. Here's a non-exhaustive list of compatible OPAs: OPA1656, OPA1602, OPA2134, NE5532P, LME49720, LM4562, MUSES02, MUSES8920, NJM4580, NJM4556, NJM2068, OP249, AD827, etc.
Please take care not to damage the device or the OPAs when replacing or handling them. Any damage to the device caused by improper handling by the user (reverse mounting of OPAs, mounting of non-compatible OPAs, etc.) will invalidate the product warranty. Please refer to the manual to carry out the operation.
3E Audio A7: Quality components
Rubycon 63V 1000uF capacitors
Rubycon capacitors meet high current requirements, reducing noise and improving THD.
Flat wire coils
Flat-wire coils
The coils used in the amplifier provide improved linearity and reduced distortion, while delivering the best performance whatever the load.
TDK capacitors
TDK capacitors
These highly reliable LC filter capacitors ensure optimum audio performance.
3E AUDIO A7 amplifier PCB photo
3E Audio A7 overview
Overview of the 3E Audio A7
1Left channel status LED
2RCA input status LED
3Multifunction button
4XLR input status LED
5Right channel status LED
6Balanced XLR/Jack 6.35mm combo input
7RCA input
8RCA gain control
9Speaker terminal output
10Volulme bypass
1138V-48V DC power supply via DC jack
3E Audio A7/A7 Mono test by Audio Science Review
"If my memory serves me right, 3e audio was the first company to bring us high performance TI TPA3255 class D amplifiers with PFFB. While they have more competition now, it is clear they intend to stay on top of this game, squeezing every bit of performance out of this architecture, while providing nice feature set. We are talking high performance, high power amplifiers that are tiny yet deliver what people need in most cases. I am happy to recommend 3e audio A7 / A7 Mono stereo audio amplifiers."
Product typeClass D amplifier
ChannelsStereo
Amplification chip2x TI TPA3255
OPADual OPA OPA1612A
StructurePFFB
Inputs1x Single-ended RCA input
1x Balanced XLR/jack 6.35mm combo input
Output1x Speaker terminal output
Input impedanceRCA : 10KΩ
XLR/TRS : 20KΩ
Volume attenuation-50dB
Volume bypass
RCA gain control
Audio specifications (RCA IN)
THD+N (5W)0.0007% @ 4Ω
0.0006% @ 8Ω
SNR (1% THD+N, 1KHz, A-wt)123dB
Dynamic range (1% THD+N, 1KHz, A-wt)123dB
Frequency response (±0.5dB)20Hz-35KHz
Noise (A-wt)< 20uVrms
Crosstalk-100dB
Gain26dB / 29dB
Input sentivity1.75Vrms
Output power (1% THD+N)2x 250W @ 4Ω
2x 140W @ 8Ω
Output power (10% THD+N)2x 300W @ 4Ω
2x 180W @ 8Ω
Output impedance2Ω-16Ω
audio specifications (XLR IN)
THD+N (5W)0.0006% @ 4Ω
0.0005% @ 8Ω
SNR (1% THD+N, 1kHz, A-wt)126dB
Dynamic range (1% THD+N, 1KHz, A-wt)126dB
Noise (A-wt)< 15uVrms
Crosstalk-110dB
Gain20dB
Input sensitivity3.5Vrms
2x 140W @ 8Ω
2x 180W @ 8Ω
Power supply38V-48V DC 5A/10A (The supplied power supply operates on 110V and 230V)
Power consumptionOFF: < 0.4W
ON (no audio): 9W
Dimensions170 x 168 x 46mm
Weight1000g
Package1x 3E Audio A7 amplifier
1x 48V 10A mains adapter
InputXLR
InputJack 6.35mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)250.0
8 reviews
vraiment mitigé
Reçu dans les temps. Merci audiophonics.
Mon installation : Nad C368 KEFQ350 et Davis Acoustic Olympia One Master de 2021.
le son dans son ensemble est bon, voir superbe, j’entends bien mieux certains instruments en arrière plan, les basses sont tendues, les médiums à leurs places, les aigus neutres.
J'ai acheté ce produit pour mieux alimenter mes Kef en courant. C'est choses faites, c'est beau.
Cependant sur certains titres, peut et tant mieux, mais il y a une projection sur la fin des derniers notes, j'attribue cela l'aop 1656 qui est légèrement trop nerveux, mais il est précis, transparents, et limpide ce qui me plait.
J'ai choisis cet appareil pensant pouvoir changer les aop facilement et donc le faire évoluer. Il faut savoir qu'il y a un troisième aop juste derrière une prise XLR, pour préparer le signal, cela à quand même une importance. C'est bien beau de changer les deux aop visible en retournant l’appareil, mais avoir la possibilité de changer en entrée le tout premier aop, cela peut être très pertinent.
Comment faire du bon boulot sans retirer la carte? Retirer les deux aop visible par le dessous de l'appareil me semble brouillon, il faut vraiment faire attention. Donc j'ai suivit les instruction pour retirer la carte, puisque cela est faisable en retirant les quelques visses.
Il n'en n'est rien, la carte ne bouge pas d'un yota, j'ai contacté la marque qui me donne la marche à suivre, que je viens déjà de réaliser. On dirait que le carte est collé, elle ne bouge pas d'un millimètre.
Donc pour un appareil qui se veut polyvalent dans le changement d'aop, pour ma part, ce n'est pas possible. Franchement quelle idée de coller un carte qui ne bouge pas malgré le fait qu'elle soit faite pour cela justement. J'ai tout essayer. Je souhaitais y installer les aop 2210 et voir le troisième aop qui s'y trouve.
C'est dommage, il me plaisait quand même. Je reviendrais changer mon avis si jamais.
This review has been posted for 3E AUDIO A7 Class D Stereo Amplifier PBTL 2xTPA3255 2x250W 4 Ohm
Le petit ampli qui envoie du lourd !
J'utilise le 3E Audio A7 comme bloc de puissance. Il est compact avec une alimentation externe 48V GaN, conçu pour un fonctionnement simple en bloc de puissance avec un préamplificateur.
Choix bypass ou volume sur la face arrière, réglage de gain en deux positions pour une meilleure adaptation avec le préamp.
Bouton principal pour allumage/arrêt (appui long) et commutation RCA/XLR (appui court).
Boîtier légèrement chaud en fonctionnement, conforme et rien de rédhibitoire pour ce type d'appareil.
Au niveau rendu, celui-ci et globalement neutre avec de la transparence, sans coloration notable : grave contrôlé, médiums nets, aigus précis sans dureté. Timbre vocal naturel et texturé.
La scène sonore est étendue avec une bonne séparation stéréo et suivi instrumental clair, même à faible volume où l'équilibre tonal persiste.
Petits bémols : alimentation externe volumineuse. Une version avec alim intégrée serait un gros plus (pour une meilleure intégration etc..).
Absence de trigger 12V sur la version française, contrairement à aux modèles US (voir photos du test ASR).
Indicateur rouge pour RCA/XLR, couleur potentiellement trompeuse (rouge = erreur) par rapport au vert standard.
Very impressive A7 stereo power amplifier
I must say I'm really impressed by this small power amplifier from 3e audio. It comes standard with OPA1656 op amps and not 1612 as the description says. No problem. The sound is very transparent and it gives enough gain to my Wharfedale Lintons. I have tested 5-6 different amplifiers with the TI TPA 3255, and this is the best implementation so far. Combine it with a Wiim Ultra and good medium priced neutral speakers. It's all you need. Sure my Purifi Eigentakt 2. gen. has much more gain to help with low volume mixed/mastered classical vinyl/CDs and streaming video with low volume and quality sound, but for everything else this 3e audio amplifier is all you'll ever need. It's a run and buy recommendation!
Et il chauffe moins que les Fosi v3 mono .
J’ai oublié de parler de la température des amplis et je me permets de compléter mon dernier avis pour vous dire que j’avais préféré acheter des ventilateurs de 12 cm pour refroidir mes blocs Fosi v3 mono car même si ces blocs ne deviennent jamais brûlants , ils sont quand même bien chauds .
Avec les 3E AUDIO A7 la température est juste tiède et je n’ai plus l’utilité de mes ventilateurs .
Mieux que les Fosi V3 ?
Après avoir possédé 4 FOSI V3 mono avec une alimentation par bloc de 48v/5v que j’utilisais avec le gain max à 31db, j’étais prêt à en reprendre 4 de plus .
Malheureusement Fosi a décidé de changer le gain de leur blocs V3 et le limiter à 25db . Cela ne correspond plus à mes attentes car mon préampli a un niveau de sortie bas .
Sur les conseils d’Audiophonics j’ai essayé un 3A AUDIO A7 .
Je suis vraiment très très étonné des impressions d’écoutes.
Sur le gain maxi à 29db cet ampli de puissance stéréo délivre une puissance semblable aux blocs Fosi mais avec un son qui paraît encore plus plein et avec une image tri-dimensionnelle encore plus précise . Tout cela reste très subjectif mais je peux vous assurer que si ce n’est pas mieux c’est au moins aussi bien que les Fosi .
En fait je trouvais les Fosi V3 mono assez proches de mes blocs Purifi 1et400 et là pour moi les 3E AUDIO A7 s’en rapprochent encore davantage .
Si vous n’avez pas besoin de 220w/8 Ohms et que les 130w du 3E AUDIO A7 sont suffisants , il vous sera bien difficile à l’aveugle de dire qui est en train de jouer .
Ces 3E AUDIO À7 sont plus lourds que les FOSI V3 mono et laisse une impression de meilleure qualité .
Je remercie ce conseil d’achat d’Audiophonics .
Cet amplis sont vraiment très très bons .
3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A7 amplifier...
