AIYIMA A80 Integrated Amplifier
With its A80, Aiyima unveils a small integrated amplifier packed with audiophile features and components. It's primarily based on an ESS9038Q2M DAC chip and a TPA3255D2 amplifier chip. This enables it to support high-resolution sampling rates up to PCM 32bit 384kHz and DSD256, as well as delivering up to 2x120W of power under 4 ohm with its supplied 48V 5A power supply. Added to this is a QCC3040 Bluetooth receiver chip for reliable wireless connection thanks to AAC, SBC, aptX, aptX LL and aptX codecs.
4.7 / 5
Reference : 20401
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 05-08-2025.
Aiyima A80 Integrated Amplifier Class D Bluetooth 5.1 TPA3255 2x120W 4 ohm
Photo of AIYIMA A80
To complete the package, there's also a handsome color display for easy navigation between the amplifier's various parameters and access to different display modes, such as a vumeter. In terms of connectivity, the amplifier features a full range of digital and analog inputs, including USB-C, Toslink optical, coaxial, RCA and balanced stereo TRS 6.35mm jack, while output is via speaker terminals. As an added bonus, it also features a 12V trigger input and a 3.5mm jack auxiliary output, enabling it to be connected to an active subwoofer or a second amplifier.
Aiyima A80: An audiophile chipset
The Aiyima A80 is an amplifier based on the combination of an ESS ES9038Q2M DAC chip, a SA9137L USB interface and a TPA3255D2 amplifier chip. This chipset enables it to support high-definition sampling rates up to PCM 32bit 384kHz and DSD256, while delivering up to 2x120W under 4 ohm with its 48V 5A power supply. In addition, the NJW1194 digital volume control chip allows adjustment of the bass and treble tones for a tailor-made sound experience.
The AIYIMA A80 chipset
AIYIMA A80 OPAs
Aiyima A80: Easily replaceable DIP8 OPAs
The Aiyima A80 amplifier's preamplifier stage features DIP8-mounted OPA1656 and NE5532 AOPs for easy replacement. Here's a non-exhaustive list of compatible OPAs: RT3609SM, OPA2604, OPA2134, LM4562, JRC5532, OP275GSZ, OPA1612.
Please take care not to damage the device or the OPAs when replacing or handling them. Any damage to the device caused by improper handling on the part of the user (reverse mounting of OPAs, mounting of non-compatible OPAs, etc.) will invalidate the product warranty.
Aiyima A80: PFFB circuitry
The Aiyima A80 amplifier benefits from a PFFB (Post Filter FeedBack) circuit that greatly optimizes performance while significantly reducing distortion. It also enables the amplifier to remain stable even in difficult conditions.
Photo of the AIYIMA A80 circuit
Aiyima A80 : Bluetooth 5.1
The Aiyima A80 features a QCC3040 Bluetooth receiver chip for reliable, stable wireless connection with AAC, SBC, aptX, aptX LL and aptX HD codecs.
AIYIMA A80 Bluetooth 5.1 functionality
Aiyima A80: A beautiful color screen
The A80's front panel features an attractive color display with a pleasant interface for easy navigation through the device's various parameters and settings. Various display modes are also available, including a vumeter.
The AIYIMA A80 screen
Aiyima A80: 48V 5A power supply
A 48V 5A power supply is supplied with the Aiyima A80. This enables it to deliver up to 2x120W into 4 ohm, but if you want a more substantial power reserve, you can obtain it with a 48V 10A power supply. In fact, the Aiyima can deliver up to 2x250W into 4 ohm with a more powerful power supply.
AIYIMA A80 power
Aiyima A80 overview
AIYIMA A80 overview
1Display
2IR receiver
3Bluetooth antenna
4Multifunction button
5Bluetooth antenna connector
6USB-C input
7Toslink optical input
8Coaxial input
9Balanced TRS 6.35mm jack line input
10RCA line input
11Trigger in 12V
12AUX jack 3.5mm output
13Speaker terminal output
1424-48V DC power supply via DC jack
AIYIMA A80 tes by Audio Science Review (Amirm)
Usually, any digital input in this class of amplifier is a "checklist item." In the A80, we have a serious DAC that provides a transparent path to the amplifier. The design is excellent given the wide high res display which can show levels, spectrum, etc.. Performance overall ranks from very good to excellent for the class.
Product typeIntegrated amplifier
Amplification typeClass D
Amplification chipTPA3255D2
AOPOPA1656
NE5532
DAC chipESS ES9038Q2M
Volume controlNJW1194
Bluetooth chipQCC3040
Inputs1x USB-C
1x Coaxial
1x Toslink optical
1x RCA line input
1x TRS 6.35mm jack balanced line input
Bluetooth
OutputsSpeaker terminals
1x AUX jack 3.5mm output
Supported sample ratesUSB: PCM up to 32bit 384kHz, Native DSD up to DSD256
Coaxial / Toslink optical: PCM up to 24bit 192kHz
USB compatibilityWindows 10/11
Mac OS
Linux
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD
Output power2x 120W @ 4 ohm (48V 5A)
2x 110W @ 6 ohm (48V 5A)
2x 102W @ 8 ohm (48V 5A)
Distorsion0.006%
SNRRCA and TRS : ≥ 109dB
Frequency response20Hz-20Khz (±0.5dB)
Input sensitivityRCA : 2Vrms
TRS : 3.6Vrms
Output impedance4-8Ω
Sensitivity of AUX jack 3.5mm output2V
Supply voltage24-48V DC
Dimensions155 x 123 x 41mm
Weight850g
Package1x Aiyima A80
1x Bluetooth antenna
1x Bluetooth remote control
1x Toslink optical cable
1x USB-A to USB-C cable
1x 48V 5A power supply
InputJack 6.35mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)120.0
Remote ControlYes
3 reviews
Un très bon rapport qualité prix
Dans un volume contenu, ce petit amplificateur delivre un excellente performance sonore et une neutralité appreciable dans le bas du spectre. L'afficheur est un pur bonheur pour les yeux. Néanmoins, les entrées trs n'offrent pas un gain notable par rapport aux classiques RCA ( intérêt?) et il manque une entree hdmi pour ma télé : 4 étoiles pour les fonctionnalités.
This review has been posted for AIYIMA A80 Integrated Amplifier Class D Bluetooth 5.1 TPA3255 2x120W 4 Ohm
Complet
Après un mois d'usage, je dirais : "Conforme au descriptif" : formule passe-partout pour confirmer qu'il s'agit d'un produit de qualité " à composants audiophiles", sans point faible significatif, surtout pour le prix, et pilotant efficacement, excusez du peu, des DYNAUDIO emit 50 (raisonnablement, hein, sans chercher à faire trembler les murs non plus ! ) avec l'alimentation d'origine, et ce dans mon salon de 25 m2 ; je n'ai donc pas besoin de prendre l'adaptateur secteur doublant la puissance. Merci Audiophonics pour l'info et surtout pour ne pas pousser inutilement à la consommation...
Cet ampli est aussi efficace en vinyle sur entrée analogique qu'avec le lecteur réseau sur l'entrée optique...
Je recommande donc aussi bien cet ampli Aiyima 80 qu'Audiophonics...
Ça marche !
C'est mon première ampli classe D et j'en suis très content pour le moment.
La qualité est plutôt pas mal du boîtier et l'animation de l'ampli est sympa.
J'ai acheté cet ampli pour réutiliser mes Elipson Planet L avec son caisson pour mon ordinateur et ça marche assez fort.
Je l'utilise en optique sur mon pc et les sorties TRS pour ma carte son pour instrument et aucune latence.
Le son est vraiment très bon pour un si petit ampli.
With its A80, Aiyima unveils a small integrated amplifier packed with audiophile features and components. It's primarily based on an...
