Avec cette entrée, le son s'avère d'abord inaudible. On commence à entendre petit à petit en augmentant le volume. Et puis tout d'un coup, le son arrive à volume très élevé !
C'est tout simplement inutilisable au quotidien !
Amplifier Two-Way Bluetooth 5.2 aptX HD 2x50W 4Ω
The Arylic B50 is an extremely versatile and practical Bluetooth 5.2 amplifier, endowed in addition to its wireless connectivity with a wide panel of connectors allowing it to adapt to all situations. Its amplification circuit offers a power of 2x50W under 4Ω or 2x30W under 8Ω.
On the Bluetooth transmission side, the B50 is equipped with a Qualcomm QCC3040 chip, allowing bi-directional operation. Thus, the amplifier can both receive a signal from a Bluetooth source and transmit an audio stream to a wireless headphone or speaker. This chip also supports the aptX and aptX HD codecs for superior wireless audio quality.
Finally, for its connectivity, the Arylic B50 offers USB-C, USB-A (USB Host), ARC compatible HDMI, optical, stereo RCA and a phono input. For the outputs, there are speaker terminals and a subwoofer output on RCA.
The free IOS and Android GO CONTROL app lets you use a wide range of features with the Arylic B50. In fact, this app gives you access to an equalizer, a source selector and enhances the BP50's user experience.
The ACPWorkBench tuning tool lets you make the adjustments you need to personalize your listening experience. In particular, this tool lets you set the frequency of each channel, while adjusting their balance. You can also customize equalizer settings and more.
| Specifications | |
| Product type | Amplifier |
| Amplification type | Class D |
| Inputs | Bluetooth 5.2 1* USB-C 1* USB-A (USB Host) 1* Optical Toslink 1* Stereo RCA line input 1* Stereo RCA Phono input (MM/MC) 1* HDMI ARC |
| Outputs | Bluetooth 5.2 Speaker terminals 1* RCA subwoofer output |
| Bluetooth version | 5.2 |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD |
| Output power | 2*50W @ 4Ω, 24V 2*30W @ 8Ω, 24V |
| Frequency response | 20Hz - 20kHz |
| THD+N | < 0.1% @ 1W, 1kHz |
| SNR | > 93dB |
| Line input level | 2Vrms |
| Subwoofer output level | 3Vrms |
| Subwoofer output cutoff frequency | 250Hz |
| General | |
| Supply voltage | 24V 4.16A (Included) |
| Dimensions (L*P*H) | 185*155*50mm |
| Weight | 900g |
| Color | Black |
| Package | 1x Arylic B50 1x Remote control 2x Antennas 1x Power supply |
| Input | Bluetooth |
| Input | HDMI ARC |
| Input | USB |
| Input | Optical |
| Input | Phono |
| Input | RCA |
| Output | Subwoofer |
| Output | Speaker terminal |
| Output | Bluetooth |
| Color | Black |
| Channel | 2.1 |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | N/A |
| Power (W) | 50.0 |
| Remote Control | No |
Average votes 3.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Patrick R.
Christophe B.
