Class D 2.1 Amplifier TDA7498E Bluetooth 5.0 2x120W 4Ω
The Fosi Audio BL20C is a small, efficient and affordable Class D amplifier based on a TDA7498E chip, allowing it to develop a power of 2x150W under 4Ω. In addition to a stereo RCA input, the BL20C provides USB-A Host to connect a storage device such as a USB flash drive as well as Bluetooth 5.0 reception capability, so it is possible to stream your music and control the playback wirelessly directly via a smartphone or tablet for example. On the output side, in addition to the speaker terminals, the amplifier offers a subwoofer output for the integration of a 2.1 audio system. In addition, the BL20C offers a tone control on the front panel, with the ability to adjust the level of bass and treble.
| 1 | Previous track button |
| 2 | Multifunction button |
| 3 | Next track button |
| 4 | ON-OFF / input selection switch |
| 5 | Power LED |
| 6 | Bluetooth/USB LED |
| 7 | USB-A Host input |
| 8 | Bass control |
| 9 | Treble control |
| 10 | Volume control |
| 11 | Bluetooth antenna |
| 12 | RCA input |
| 13 | Subwoofer output |
| 14 | Speaker output |
| 15 | Power supply input |
| Specifications | |
| Product type | Amplifier |
| Ampification type | Class D |
| Amplification chip | TDA7498E |
| Number of channels | 2.1 |
| Inputs | Bluetooth 5.0 1x Stereo RCA 1x USB-A Host |
| Outputs | Speaker terminals 1x Subwoofer output (RCA) |
| Output power | 2x120W @ 4 Ohm (@35V / 1%THD) 2x150W @ 4 Ohm (@35V / 10% THD) 2x105W @ 4 Ohm (@32V / 1%THD) 2x135W @ 4 Ohm (@32V / 10% THD) |
| SNR | ≥ 98dB |
| THD | ≤ 0.05% |
| Frequency response | 20Hz-20kHz (±3dB) |
| General | |
| Supply voltage | 19 - 35VDC |
| Color | Black |
| Package | 1x Fosi Audio BL20C 1x Power supply 24V 1x Bluetooth antenna |
| Input | RCA |
| Input | USB |
| Input | Bluetooth |
| Output | Speaker terminal |
| Output | Subwoofer |
| Color | Black |
| Channel | 2.1 |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TDA7498E |
| Power (W) | 120.0 |
| Remote Control | No |
