FOSI AUDIO V3 Stereo Class D Amplifier TPA3255 2x225W 4 Ohm
The V3 from Fosi Audio is a compact and powerful amplifier at a very affordable price. Despite its simplicity, the V3 amplifier uses high-quality audiophile components such as a TI TPA3255 amplifier chip and delivers up to 2x225W @ 4Ω.
4.8 / 5
Reference : 17954
109,00 €tax incl.
90,83 € tax excl.
This product is temporarily unavailable.
FOSI AUDIO V3
FOSI AUDIO V3 Amplificateur Stéréo Class D TPA3255 2x300W 4 Ohm
The V3 from Fosi Audio is a compact, powerful amplifier that also remains very affordable. Despite its simplicity, the V3 amplifier uses high-quality audiophile components such as a TI TPA3255 amplification chip, Japanese and German Elna and Wima capacitors and DIP8-mounted NE5532 AOPs, giving you the option of replacing them if you want a particular sound signature. This amplifier is ideal for integration into a HiFi system requiring high power, since it delivers up to 2x225W @ 4Ω. Connections include a stereo RCA input, speaker terminals and a 3.5mm pre-out jack.
A powerful amplification stage
The Fosi Audio V3 uses a TI TPA3255 amplification chip, which delivers true sound quality with class D efficiency and very low distortion. Coupled with audiophile components, the TI TPA3255 allows the V3 to maintain high stability even at very high power. In terms of OPA, the Fosi Audio V3 is equipped with DIP8-mounted NE5532, making them easy to replace. They can be replaced by MUSES02s, AOP2604APs or AOP2134PAs, for example.
Intelligent volume control
The volume control is based on a logarithm (Taper A pot), providing much finer control that is better adapted to the human ear. This makes the final listening experience more immersive and pleasant.
Efficient heat dissipation
The heat dissipation system of the Fosi Audio V3 allows it to be used at high power for extended periods without compromising its performance or causing harmful effects. In fact, the V3's enclosure incorporates vents on its upper and lower sides as well as an internal radiator. This innovative cooling system design greatly improves the airflow and heat dissipation of the Fosi Audio V3 amplifier.
Simple and effective connectivity
1Power indicator
2Power switch / Volume control
3Stereo RCA input
43.5mm pre-out Jack
5Speaker terminals
6Power plug DC 24V-48V
Test du FOSI AUDIO V3 par Audio Science Review
"The Fosi Audio V3 is well implemented and brings nice looks and design at a bargain price. Company is also quite receptive to customer input and is a delight to work with behind the scenes. I don't know what else we could ask for!"
Test du SMSL SU-9 par Audio Science Review
Product typeStereo class D Amplifier
Inputs1x Stereo RCA
Outputs1x Speaker terminals
1x 3.5mm pre-out jack
Amp. chipTI TPA3255
OPA2x NE5532
Output power2x 225W @ 4Ω (THD+N 1%)
2x 160W @ 8Ω (THD+N 1%)
2x 270W @ 4Ω (THD+N 10%)
2x 190W @ 8Ω (THD+N 10%)
Speaker impedance2Ω - 8Ω
Frequency response20Hz - 20kHz (±0.1dB)
SINAD≥ 88dB
THD0.003%
SNR≥ 110dB
Volume controlLogarithm A pot
Power supply24 - 48V DC
Dimensions166 x 105 x 35 mm
Package1x Fosi Audio V3
1x Power adapter 48V 5A
OutputSpeaker terminal
OutputJack 3.5mm
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)225.0
10 reviews
Un ampli intéressant, plein de vivacité et d'une écoute plaisante.
Lui laisser le temps de roder ses composants ...
En baissant trop le volume on tendance a l'eteidre.
En ce moment j’écoute "Dark side of the moon" pour préparer ma bolognaise...
This review has been posted for FOSI AUDIO V3 Stereo Class D Amplifier TPA3255 2x225W 4 Ohm
En ce moment "Dark side of the moon" pour préparer ma bolognaise...
belle surprise
je cherchais un ampli pour alimenter une paire de vénérables ditton 66 , sachant que la classe D a cette singularité d'y parvenir sans se ruiner .
l'essai est transformé ; les 30 cm des graves sont tenus , le MD 500 des ditton permet aux médiums de s'exprimer avec amplitude mais sans excès et pas de brillance dans les aigus ;
ça fonctionne déjà fort bien avec les aop 5532 d'origine
testé avec les oracles 2.2 l'équilibre des registres en maintenu avec une touche de douceur
les muses 02 respectent toujours l'équilibre graves méduims aigus et amènent un élargissement de la scène
superbe stéréo , excellente dynamique
je reste avec les muses 02
je n'ai pas fait l'essai avec mes klipsch rf82 , j'ai peur que ça brille un peu dans le haut , mais avec les ditton et toutes autres enceintes de ce type le fosi doit fonctionner à merveille
mes sources : airdac nuforce + fichiers flac du pc / platine cd technics sl pg 420
bref un excellent rapport qualité prix pour ceux qui peuvent se contenter d'une seule entrée analogique
j'envisage l'ajout d'un dac XDUOO XQ 50 pro 2 ou une aiyima T8 pour étendre la connectique
J'ai acheté cet ampli en remplacement de mon Aura Vita tombé en rade. Pour le prix il est très bon pas de problème pour alimenter mes colonnes trois voies acoustic energy. Je trouve que l'aigu est un peu "acide" et manque de charme mais encore une fois pour le prix c'est très bien. Quand mon Aura sera réparé il servira d'ampli de bureau. Envoi très rapide et soigné de la part d'audiophonics.
Trés satisfait !
Il vient remplacer un vieux Technics SU-V460. Le Fosi est alimenté par un préampli DAC Tangent et alimente des Focal Chorus 705v.
Tout s'accorde très bien, un son clair et précis comme ce que je souhaitait.
The V3 from Fosi Audio is a compact and powerful amplifier at a very affordable price. Despite its simplicity, the V3 amplifier uses high-quality...
