By buying this product you get 84 loyalty points
Tube Amplifier / Headphone Amplifier 12AU7 EL34-B Bluetooth aptX 2x6W 8 Ohm
The Original Audio OPA-4A is a high quality tube and headphone amplifier combo, based on the joint use of two 12AU7 tubes for the power stage and two EL34 tubes for the single-ended output stage within a linear circuit. The OPA-4A reveals a warm, smooth and musical sound, typical of tube designs, without losing its vigor. Its architecture allows it to develop a power of 2x6W under 8Ω for the speaker output and 2x4W under 32Ω for the balanced headphone output or 2x900mW under 32Ω for its single-ended headphone output. An ALPS 27 potentiometer allows a fine volume control of the sound level.
For its connectivity, the OPA-4A offers a balanced input on stereo XLR and single-ended on stereo RCA, as well as a Bluetooth connectivity. The latter allows you to broadcast your music remotely, from a smartphone for example. It also supports the aptX transmission codec, allowing to reach a quality of restitution close to that of the CD.
On the output side, there are speaker terminals at the back, but also a balanced headphone output in XLR 4-pole format and a single-ended headphone output on 6.35mm jack.
Product type | Tube amplifier Headphone amplifier |
Inputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA Bluetooth |
Outputs | Speaker terminals 1x Balanced 4 poles XLR headphone output 1x Single-ended Jack 6.35mm headphone output |
Tubes | 2x 12AU7 2x AL34 |
Output power | 2x 6W (4-8Ω) |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX LL |
Headphone amplifier power | Balanced output: 2x 4000mW @ 32Ω Single-ended output : 2x900mW @ 32Ω |
Frequency response | 20Hz ~ 50kHz (-1.5dB) |
THD | 0.5% (1kHz) |
SNR | 89dB |
Input sensitivity | 350mV |
Input impedance | 100kΩ |
Channel balance | < 0.5dB |
Power supply | 220V 50Hz |
Dimensions | 285 x 190 x 175mm |
Weight | 13kg |
Color | Black |
Operating temperature | 0°C / +40°C |
Input | Bluetooth |
Input | XLR |
Input | RCA |
Output | XLR |
Output | Speaker terminal |
Output | Jack 6.35mm |
Color | Black |
Class | Class A / AB |
