SABAJ A8 Amplifier Class D ICEpower 2x125W / 1x500W 4 Ohm
Sabaj unveils with the A8 a compact and powerful Class D amplifier, based on an ICEpower amplifier chip, capable of a clear and faithful reproduction. Easy to use, its connectivity will allow you to use its RCA input for a stereo system or its balanced XLR input to make it work in bridged mono and have a high output power.
By buying this product you get 33 loyalty points
Reference : 15934
339,00 €tax incl.
282,50 € tax excl.
Sabaj A8
Sabaj A8 Amplificateur Class D ICEpower 2x125W / 1x500W4Ω
Sabaj unveils with the A8 a compact and powerful Class D amplifier, based on an ICEpower amplifier chip, capable of a clear and faithful reproduction. Easy to use, its connectivity will allow you to use its RCA input for a stereo system or its balanced XLR input to make it work in bridged mono and have a high output power. The latter can also be used to connect a passive subwoofer or to connect two A8s and enjoy a high power stereo amplifier. The output is done on classic speaker terminals. The A8's solid industrial style enclosure is optimized to efficiently dissipate the heat generated by the unit's components.
Product typeAmplifier
Amplification typeClass D
Amplification boardICEpower
Inputs1x Stereo RCA
1x Mono XLR
OutputSpeaker terminals
Output power2x125W @ 4Ω
2x68W @ 8Ω
1x500W @ 4
1x270 @ 8
THD+N0.002%
SNR117dB
Channel separation96dB
Input senstivity280mV
Input impedance47kΩ
Consumption40W
Standby consumption< 0.6W
Dimensions200 x 59 x 208mm
Weight1470g
ColorSilver
InputXLR
ColorSilver
Channel2 (Stereo)
Channel1 (Mono)
Amplifier chipIce Power
Power (W)500.0
Power (W)125.0
Sabaj unveils with the A8 a compact and powerful Class D amplifier, based on an ICEpower amplifier chip, capable of a clear and faithful...
