Stereo Amplifier Class D TPA3251 2x140W 4 Ohm
This affordable Class D amplifier is based on a TOPA3251D2 amplifier chip, ensuring a power of 2x140W under 4Ω and this with high efficiency. It will therefore have no trouble accompanying most speaker models. Moreover, it takes advantage of the PurePath Ultra HD technology, allows to maintain a very low level of distortion on the whole frequency band, while offering a beautiful sound precision.
3.3 / 5
Reference : 15391
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 28-05-2025.
Amplifier
Stereo Class D TPA3251 2x140W 4 Ohm
Amplificateur Stéréo Class D TPA3251 2x140W 4 Ohm
The amplifier benefits from a nice design quality, using proven audio components. The power supply stage uses two Nichicon 50V 1000µF capacitors to filter the electrical signal.
As far as connectivity is concerned, this model remains simple, with a stereo RCA input as well as a 3.5mm jack output and of course an output on speaker terminals.
Product typeAmplifier
Amplifier typeClass D
Impedance4-8Ω
Amplification chipTPA3251D2
Power output2x 140W @ 4Ω, THD+N 1%, BTL
2x 175W @ 3Ω, THD+N 1%, BTL
THD+N0.005% @ 1W 4Ω
PSRR60dB
SNR> 111dB (A-Weighted)
Dimensions179 x 104 x 43mm
Power supply24-36VDC (sold separately)
Weight542g
OutputSpeaker terminal
OutputJack 3.5mm
Channel2 (Stereo)
Amplifier chipTPA3251D2
Power (W)140.0
3 reviews
Très bon ampli - pourquoi mettre plus cher?
Je l'ai alimenté par une carte SMPS300RS 36V qui alimente 2 de ces amplis en fait (je pilote 2 enceintes actives), sur des HP 6-8 Ohm. La puissance de 300 W suit.
Concernant la taille des connecteurs de sortie: aucun soucis si vous utilisez des prises bananes.
Les Ampli OP sont soudés directement, donc si vous voulez les changer, pas évident. Je n'en éprouve pas le besoin: le souffle est inaudible sauf si vos enceinte sont à 50 cm de vos oreilles.
This review has been posted for Stereo Amplifier Class D TPA3251 2x140W 4 Ohm
NOT recommended
I cannot recommend this amp.
The case amp is very small, the output binding posts are ridiculously tiny and too close to each other.
The posts cannot be used with whatever "serious" cable or connector other than bananas.
I purchased it for testing purpose in an active system, but
I'm not able to judge the sound quality, cause the amp became dead silent at the very first use due to a supposed short on the output binding posts.
My fault, it's clear.
Simple et efficace
Marche a la perfection, rapport prix / rendement au top.
Petit b mol pour le knob volume, manque de solidité a l'intégration mais rien de terrible.
Pd: Bornier HP de petite taille (2 mm) à tenir en compte pour l'achat de câble et/ou fiche banane.
This affordable Class D amplifier is based on a TOPA3251D2 amplifier chip, ensuring a power of 2x140W under 4Ω and this with high...
