SVS PRIME WIRELESS PRO SOUNDBASE Integrated Amplifier Class D HDMI ARC eARC WiFi AirPlay 2 Bluetooth 5.0 aptX 2x150W 4Ohm
The SVS Prime wireless pro SoundBase is a robust 300w stereo amplifier (150 watt per channel) with a 192 KHz/24-bit DAC housed in a compact and high-tech box. It is able to drive any loudspeaker to its full potential with plenty of dynamics, powerful bass and crystal clear sound. Its internal components are of audiophile quality. This integrated audio amplifier is perfect for people using streaming services.
By buying this product you get 79 loyalty points
Reference : 17701
799,00 €tax incl.
665,83 € tax excl.
Shipping date: 05-08-2025.
SVS PRIME WIRELESS PRO SOUNDBASE Amplificateur intégré class D 2x150W HDMI ARC / eARC WiFi AirPlay 2 Bluetooth 5.0 aptX
The SVS Prime Wireless Pro SoundBase is a robust 300W stereo amplifier (150W per channel) with a 192 KHz/24-bit DAC housed in a compact and high-tech box. It is able to drive any speaker to its full potential with plenty of dynamics, powerful bass and crystal clear sound. Its internal components are of audiophile quality. This integrated audio amplifier is perfect for people using streaming services. Among other things, it can wirelessly stream high-resolution lossless audio via WiFi, Apple Airplay 2 for iPhone and iOS and Chromecast for Android phones and other devices. The Bluetooth function is also present.
Its other strong point lies in its fairly complete connectivity with an HDMI ARC / eARC input and a subwoofer output for deeper and immersive bass.
SVS PRIME WIRELESS PRO SOUNDBASE Amplificateur intégré class D 2x150W HDMI ARC / eARC WiFi AirPlay 2 Bluetooth 5.0 aptX SVS PRIME WIRELESS PRO SOUNDBASE Amplificateur intégré class D 2x150W HDMI ARC / eARC WiFi AirPlay 2 Bluetooth 5.0 aptX
Dynamic and massive output sound
With its Class D amplifier of 300W (2x150W) the SVS Prime Wireless Pro SoundBase allows you to broadcast powerful and impactful sound. The sound will remain clear and clean even at high volumes.
Audiophonics DAWSVS PRIME WIRELESS PRO SOUNDBASE Amplificateur intégré class D 2x150W HDMI ARC / eARC WiFi AirPlay 2 Bluetooth 5.0 aptX-S250NC Amplificateur Intégré Class D NCore DAC ES9038Q2M WiFi Bluetooth 5.0 2x250W 4 Ohm 32bit 768kHz DSD512
High resolution streaming via WiFi
Take control of your SVS Prime wireless pro SoundBase remotely in a perfectly intuitive way thanks to its WiFi connectivity. The SVS Prime wireless pro SoundBas has several wireless streaming options:
  • DTS Play-Fi: 192 kHz/24-bit lossless via Wi-Fi listening mode
  • Apple Airplay 2 for iPhone and iOS devices, Chromecast for Android phones and devices: CD quality
  • Bluetooth 5.0 with AAC and aptX codecs
  • Spotify Connect
Versatile Connectivity
1Speaker terminal
2RCA input
3Jack 3.5mm input (Aux)
4HDMI ARC/eARC input
5USB-A input
6Ethernet RJ45 input/ouput
7Subwoofer output
8RCA output
9Optical Toslink input
10IR 3.5mm input
11WiFi setup
12Bluetooth setup
13Power supply : Automatic switching 100–120V / 220–240V, 50/60 Hz
Intelligent control
The DTS Play-Fi application, available free of charge on Android and iOS, allows you to remotely control your SVS Prime Wireless Pro SoundBase. Thanks to its ergonomic and intuitive interface, simply stream your music from your smartphone. This integrated amplifier also has the option of native control via Apple Airplay 2 for iPhone and iOS, Spotify Connect and Google Chromecast for Android phones and devices.
Alexa, Siri and Google voice control is possible via supported devices as well as use in a multiroom system to enjoy your music throughout your home (DTS Play-Fi compatible products).
Finally, the front panel user interface is quite rich in terms of data display and an IR remote control is provided.
xxx
Product typeIntegrated amplifier
Amplification typeClass D
Inputs1x HDMI ARC/eARC
1x IR Jack 3.5mm
1x Jack 3.5mm AUX (input impedance: 20K)
1x Optical Toslink (96kHz)
1x Ethernet RJ45
1x USB-A
1x RCA  (input impedance: 20K)
Bluetooth (AAC and aptX)
WiFi
Outputs1x Speaker terminals
1x Pre-out stereo RCA (2V Max)
1x Subwoofer RCA (2V Max)
1x Jack 3.5mm headphone output (1V @ 32Ω max)
1x RJ45 Ethernet
Output power2x150W RMS @ 4Ω
Band width10Hz-20kHz (±1dB)
SNR100dB @1V, 2x150W
ScreenOLED 3.15"
Supported WiFi protocolsAirPlay 2
Spotify Connect
Chromecast
Power supplySwitch mode: Automatic switching 100-120V / 220–240V, 50/60Hz
Fuse
6.3A / 250V
ColorGray
Weight2.2kg
Dimensions (W*D*H)230.8*223.8*82mm 82mm
Package1x SVS Prime Wireless Pro SoundBase
1x Remote control (batteries included)
1x Power cable
InputJack 3.5mm
InputWiFi
InputHDMI ARC
InputRJ45
InputIR
OutputJack 3.5mm
OutputSubwoofer
OutputSpeaker terminal
OutputRJ45
ColorGray
Channel2 (Stereo)
Amplifier chipN/A
Power (W)300.0
Remote ControlYes
The SVS Prime wireless pro SoundBase is a robust 300w stereo amplifier (150 watt per channel) with a 192 KHz/24-bit DAC housed in a compact and...
