WIIM AMP PRO Network Amplifier Gray
An evolution of the WiiM Amp connected amplifier, the WiiM Amp Pro retains the features and functions of its predecessor, but with a few notable improvements. The WiiM Amp Pro, a high-performance connected amplifier, now features an ES9038Q2M DAC chip supporting sampling rates up to PCM 32bit 384kHz. In addition, the Class D amplification circuit using a TPA3255 chip sees its performance enhanced by the integration of an advanced feedback design (Post Filter Feedback - PFFB) for an equivalent power of 2x100W at 4 ohms.
By buying this product you get 45 loyalty points
Reference : 19340
459,00 €tax incl.
382,50 € tax excl.
Shipping date: 13-05-2025.
WiiM Amp Pro Class D Stereo Amplifier TPA3255 PFFB WiFi DLNA Chromecast Bluetooth 5.3 2x100W 4 Ohm Gray
WiiM Amp Pro picture
In terms of connectivity, Bluetooth and Wi-Fi connections are now in Bluetooth 5.3 and WiFi 6E. DLNA and Chromecast transmission protocols are still available, as is the WiiM Home application for easy control of your amplifier and access to numerous streaming platforms such as Spotify, Tidal, Deezer and Qobuz.
As far as the device's form factor and connectivity are concerned, the changes are minor. Inputs include USB, HDMI ARC, Toslink optical and RCA, while outputs include speaker terminals and a subwoofer output, enabling the WiiM AMP PRO to be integrated into a 2.1-channel system for an immersive TV or home-cinema experience.
WiiM AMP PRO
WiiM AMP
Amplification
TPA3255 + PFFB
TPA3255
DAC chip
ES9038Q2M
ES9018K2M
Output power
2x 100W @ 4 ohm
2x 60W @ 8 ohm
2x 100W @ 4 ohm
2x 60W @ 8 ohm
Supported sample rates
PCM 32bit 384kHz
PCM 24bit 192kHz
SNR
120dB
98dB
THD+N
-105dB (0.0005%)
-92dB (0.002%)
Wi-Fi
Wi-Fi 6E
Wi-Fi 5
Bluetooth
BT 5.3 (LE audio Support)
BT 5.1
Multi-Room correction
Built-in auto-correction
WiiM Amp Pro: an ultra-connected amplifier
A true network player, the WiiM Amp Pro features a WiFI 6E connection and an RJ45 Ethernet port. DLNA, Spotify Connect and Chromecast transmission protocols are supported, enabling you to access your music library in a variety of ways, whether it's networked on your computer, NAS or smartphone.
The WiiM Home app also gives you easy access to streaming platforms and web radios: Spotify, Deezer, Tidal, Qobuz, Amazon Music, Apple Music, Napster, iHeartRadio and TuneIn.
To top it all off, the WiiM Amp Pro also features two-way Bluetooth 5.3 connectivity for pairing with headphones or Bluetooth speakers.
WiiM AMP PRO, an ultra-connected amplifier
WiiM Amp Pro: new ES9038Q2M DAC chip and improved amplifier circuitry
The new ES9038Q2M DAC chip enables the WiiM Amp Pro to support ultra-high-resolution 32bit 384kHz PCM streams. The combination of this DAC chip with a TPA3255 amplifier chip with PFFB (Post Filter Feedback) boosts the performance of the WiiM Amp Pro, with a THD+N of just 0.0005% (-105dB) and an SNR of 120dB. In terms of power output, 2x100W at 4 ohms and 2x60W at 8 ohms are more than sufficient to drive bookshelf speakers, or even small column speakers.
DAC chip ES9038Q2M and TPA3255 with PFFB
WiiM Amp Pro: WiiM Home application
Intuitive and user-friendly, the WiiM Home application lets you control the WiiM Amp Pro remotely for an enhanced user experience. A gateway to various streaming services, the application also gives you access to various WiiM Amp Pro parameters, such as a 10-band parametric equalizer and predefined profiles.
WiiM Home App
WiiM Amp Pro: voice assistant and remote control
The WiiM Amp Pro is compatible with Google Assistant and Amazon Alexa voice assistants thanks to the built-in microphone on its Bluetooth remote control, or via the association of a connected speaker from one of these systems.
Photo of remote control and available voice assistants
WiiM Amp Pro: Multiroom integration
The WiiM Amp Pro can be used as a stand-alone unit or combined with other units in a multiroom system. This makes it possible to distribute music throughout the home from a centralized control point, via the WiiM Home mobile application. Playback and volume can then be managed either synchronously for all devices, or independently for each piece of equipment.
Multiple devices can be linked in multiroom mode with any compatible LinkPlay device, or with AVS Multiroom technology.
A new feature of the WiiM AMP Pro is its multiroom EQ auto-correction system.
WiiM AMP PRO overview
The WiiM Amp Pro has all the essentials in terms of connectivity, but also takes on the advantages of its predecessor, with an HDMI ARC input and a subwoofer output.
WiiM AMP PRO connectors
1HDMI ARC input
2RJ45 Ethernet port
3Stereo RCA line input
4Power supply port
5USB-A input
6Toslink optical input
7Subwoofer output
8Speaker terminals
WiiM Amp Pro test by Audio Science Review
"Almost all measurements have an “excellent” subjective rating, showing that the company has paid attention to every aspect of the design. The Amp Pro is an improvement on the original version in every aspect. The design of the device is of very good quality, with support for streaming services and sophisticated applications. The price is quite reasonable for all this functionality, power and performance."
ASR Logo
Product typeConnected amplifier
AmplificationClass D
Amplification chipTPA3355 with PFFB
DAC ChipESS SABRE ES9038Q2M
CPUQuadcore A53
InputsWiFi 6E
Bluetooth 5.3
1x RCA stereo
1x Optical Toslink
1x HDMI ARC
1x USB-A
1x Ethernet RJ45
OutputsSpeaker terminals
1x Subwoofer output
Supported sample ratesPCM 32bit 384kHz
Output power2x 100W @ 4 ohm
2x 60W @ 8 ohm
SNR120dB
THD+N0.0005% (-105dB)
Supported network protocolsDLNA
Chromecast
Voice assistant compatibilityAmazon Alexa
Google Assistant
Control applicationWiiM Home
Dolby Digital format support
Dimensions190*60*190mm
ColorGrey
Package1x WiiM AMP PRO
1x Remote control
1x Power supply cable
InputHDMI ARC
OutputSpeaker terminal
OutputSubwoofer
DAC / ADC ChipES9038Q2M
Max sampling rate384kHz
ColorGray
Channel2.1
Amplifier chipTPA3255
Power (W)100.0
Remote ControlYes
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsChromecast
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify Connect
WIIM AMP PRO Class D Stereo Amplifier TPA3255 PFFB WiFi DLNA Chromecast Bluetooth 5.3 2x100W 4 Ohm Gray
An evolution of the WiiM Amp connected amplifier, the WiiM Amp Pro retains the features and functions of its predecessor, but with a few notable...
