Input module SPDIF RS422 to AES EBU / SPDIF / SPDIF TTL / Toslink
Reference : 12552
19,90 €tax incl.
16,58 € tax excl.
- SPDIF INPUT MODULE to SPDIF, SPDIF TLL, AES EBU, TOSLINK  -
This SPDIF Coaxial to SPDIF input module allows you to output in the main SPDIF Coaxial formats, AES EBU 110 Ohm, but also TTL. The whole point of SPDIF TTL is to be able to attack audio logical interfaces. The TTL format is mainly used on sound cards, ROM DriverCD and CD mechanics as well as on DSP processing cards (mini-DSP minisharc). Thanks to these Pulse isolating transformers, this digital board also provides better stability on SPDIF digital signals. (see oscilloscope photo) at the bottom of the plug).
SETTING THE  Jumpers FUNCTIONS:
JP1 input selection:
Welding 1 and 2 = input J6
Welding 2 and 3 = input J1
JP2: soldering output selection J7 TTL
Desoldering : does not work
List of compatible CD management chipset :
CXD1125, CXD1135, CXD1165Q, CXD1167Q, CXD1167R, CXD2500, CXD2505AQ, CXD2510Q, CXD2507AQ, CXD2508AR, CXD2508AQ, CXD2515, CXD2525, CXD2545, CXD2518Q, CXD3008Q, CXD3068Q, CX23034, LC7861, LC7861, LC7862, LC7863, LC7865, LC7867, LC7868, LC78681, KS9210, KS9211, KS9212, KS5990, KS5991, KS9950, YM7121, MN6625, MN6626, M66271, MN6627971, M662720RB, SAA7210, SAA7220, SAA7340, SAA7341, SAA7345, STA1052, SAA7327H, SAA7372, TC9326, TC9236, TC9432, TC9462F, TC9474FA, YDC101B, M50423P, M65820, M65822.
This non-exhaustive list comes from the Internet and is not a guarantee of a 100% compatible functioning with the mentioned components.
This module is delivered without any mounting plug or datasheet. It is aimed at enthusiasts and professionals.
Module d'entrée SPDIF RS422 vers AES EBU / SPDIF / SPDIF TTL / Toslink
1SPDIF input
2SPDIF output (TTL level)
3SPDIF input
45VDC
5GND
6Optical Toslink output
7Coaxial output (TTL level)
8Coaxial output (500mV)
9AES/EBU output
Technical caratheristics
inputsSPDIF coaxial et SMA + SPDIF TTL
OutputsAES EBU 110 Ohm, Coaxial SPDIF SMA, SPDIF TTL SMA
Voltage DC5V
DimensionsLargeur 50mm, Longueur 70mm, Hauteur 23.5mm
Weight20g
ScrewsM3 entraxe 60x40mm
OutputOptical Toslink
OutputCoaxial SPDIF
Max sampling rateNC
Mounting typeTo weld
Interface chipNC
