This USB to I2S, DSD, SPDIF and MQA interface is equipped with an XMOS XU316 USB chip and is designed for high-fidelity audio applications.
The interface supports digital streams with a sampling frequency of up to 32bit 768kHz PCM, DSD512 on its I2S output and up to 192kHz PCM on the SPDIF output. Furthermore, it should be noted that MQA is supported here, thanks in particular to the presence of the XMOS XU316 chip.
| Specifications | |
| Type of product | Digital interface |
| Input | USB-B |
| Outputs | I2S SPDIF |
| Supported sampling rates | I2S : PCM up to 32bit 768kHz / Native DSD up to DSD512 SPDIF : PCM up to 24bit 192kHz |
| Interface chip | XMOS XU316 |
| Compatibility | Windows 7 / 8 / 8.1 / 10 / 11 (Driver required) Mac OS X10.6+ Linux Android iOS |
| Spacing holes | 22mm x 60mm |
| Clock jitter | 75pS |
| MQA support | Yes |
| General | |
| Dimensions | 35mm x 69mm (excluding connector) |
| Weight | 20g |
| Package | 1x Digital interface 1x Pin header 2x10 Pins 2.54mm |
| Input | USB |
| Output | I2S |
| Output | SPDIF |
| Max sampling rate | MQA |
