Two-Way Digital Interface Module SPDIF I2S Analog PCM9211
This digital interface module offers a bidirectional system between SPDIF (coaxial and optical) and I2S. The card also provides an analog input. Thanks to its selector, it is possible to change the direction of the transmission.
Reference : 16720
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 13-05-2025.
Digital interface board
Two-way SPDIF I2S Analog PCM9211
Module interface numérique bidirectionnelle SPDIF I2S Analogique PCM9211
This digital interface module offers a bidirectional system between SPDIF (coaxial and optical) and I2S. The card also provides an analog input. Thanks to its selector, it is possible to change the direction of the transmission. Thus, it is possible to enter in coaxial to exit in I2S and optical, to enter in I2S to exit in coaxial and optical and finally to enter in analog to exit in I2S, coaxial and optical. The module also allows to add a USB to I2S interface (sold separately).
This digital interface benefits from a quality design, including a filtered power supply, a PCM9211 digital transceiver chip, a bi-directional isolation buffer using a TI SN74HC245 chip and a SiTime A020R clock for low jitter.
The different operating modes of the module
Here are detailed the different options of this digital interface. The switches on the module allow to select an operating mode.
Module interface numérique bidirectionnelle SPDIF I2S Analogique PCM9211 Module interface numérique bidirectionnelle SPDIF I2S Analogique PCM9211 Module interface numérique bidirectionnelle SPDIF I2S Analogique PCM9211 Module interface numérique bidirectionnelle SPDIF I2S Analogique PCM9211
Diagram & Dimensions
Product typeTwi-way digital interface board
Inputs1x Coaxial
1x I2S
1x Analog
Outputs1x Coaxial
1x I2S
1x Optical Toslink
Digital TransceiverPCM9211
Supported sampling ratesPCM up to 192kHz
Dimensions69 x 45mm
Mounting holes spacing64 x 25mm
InputI2S
OutputCoaxial SPDIF
OutputSolder pad
OutputI2S
Max sampling rate192kHz
Interface chipPCM9211
This digital interface module offers a bidirectional system between SPDIF (coaxial and optical) and I2S. The card also provides an analog input....
