No featrued products
The aeco AT3-1351G is a high-quality Jack 3.5mm TRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high purity tellurium copper with 10µ gold plating, ensuring excellent conductivity and limiting signal loss. The stainless steel body is insulated from the contacts by a nylon section.
| Specifications | |
| Product type | Male Jack 3.5mm TRS connector |
| Contacts material | Tellurium copper (purity: > 99%) |
| Contacts plating | Gold 10µ |
| Insulation material | Nylon |
| Shell material | Stainless steel |
| Max cable diameter | With reducer: Ø4.5mm Without reducer: Ø6.5mm |
| Contacts resistance | < 1mΩ |
| General | |
| Color | Silver |
| Total dimensions | Ø8.9*42.3mm |
| Max cable diameter (mm) | 6.5 |
| Mounting type | To weld |
| Connectic | Male |
| Contacts number | 3 |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | Gold |
