DD DJ35AR Adapter Female Jack 2.5mm to Male Jack 3.5mm Rhodium Plated Copper
This DD DJ35AR adapter is composed of a balanced female 2.5mm jack and a single-ended male 3.5mm jack. Enjoying a beautiful design quality, its contacts are Rhodium plated, a metal that resists perfectly to oxidation and corrosion. The "T" format of this connector allows it to occupy a small space once plugged. Its body is transparent, leaving the internal circuits visible for a modern design.
Reference : 15624
27,90 €tax incl.
23,25 € tax excl.
DD DJ35AR
DD DJ35AR Adaptateur Jack 2.5mm Femelle vers Jack 3.5mm Mâle Cuivre Plaqué Rhodium
Product typeJack adapter
Connectors1x Female balanced Jack 2.5mm
1x Male single-ended Jack 3.5mm
Contacts materialCopper
Contacts platingRhodium
Body materialPC
Stainless steel
Dimensions (without plug)13 x 10 x 8.5mm
ConnecticMale & Female
ConnectorJack 2.5mm
ConnectorJack 3.5mm
This DD DJ35AR adapter is composed of a balanced female 2.5mm jack and a single-ended male 3.5mm jack. Enjoying a beautiful design quality, its...
