Kit de bonne qualité de fabrication et d'assemblage. Il m'a permis de déporter un potentiomètre de volume sur un ampli Luxman LV112 dont le potentiomètre d'origine compacte ne se trouve plus.
300mm, Ø6mm
This 300mm long potentiometer extension kit is ideal for your DIY projects and assemblies, allowing you to place the potentiometer close to the circuits in order to limit the length of the wiring between them. The kit is compatible with smooth or flat-axis potentiometers and knobs with notched axes.
The potentiometer is sold separately. The kit consists of the extension and its fixing system.
Product type | Potentiometer shaft extension kit |
Shaft dimensions | Ø6mm x 300mm |
Metal potentiometer support dimensions (included) | 50 x 12mm |
Color | N/A |
Diameter (mm) | N/A |
Shaft | Notched |
Shaft | Smooth |
Shaft | Flat |
Channel | N/A |
Resistance (Ohm) | N/A |
Tolerance (%) | N/A |
Internal width | N/A |
Internal height | N/A |
Height | N/A |
Average votes 4.3 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Michael A.
Maksym N.
Dirk H.
Akira N.
