ATOHM LD150CR04 Speaker Driver Midbass 100W 4 Ohm 91dB Ø15cm
The LD150CR04 from Atohm is a low midrange speaker. It has been designed to produce high quality 2-way systems. Its design incorporates many Made in Atohm technologies, allowing it to offer impressive performances.
Reference : 13153
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 05-06-2025.
Atohm LD150CR04
Speaker Driver Midbass 100W 4 Ohm 91dB Ø 15cm
Atohm LD150CR04 Haut-Parleur Bas Médium 100W 4 Ohm 91dB Ø 15cm
Le LD150CR04, a high performance midbass of Ø 15cm
The LD150CR04 from Atohm is a low midrange speaker. It has been designed to produce high quality 2-way systems. Its membrane is made of a specific alloy with a peripheral suspension featuring LDS (Low Diffraction Surrounding) technology. This one is characterized by a particular profile, offering a progressive splitting of the suspension at medium frequencies.
The motor benefits from FWI (Force Without Inductance) technology. This loudspeaker offers an optimized design in order to obtain a wide and symmetrical force factor. Its core is covered with a copper ring that largely limits the creation of induced currents in polar parts. This reduces and linearizes the inductance value of the winding and thus reduces distortion by odd harmonics and intermodulation, as well as a more linear and wider bandwidth.
Atohm LD150CR04 Haut-Parleur Bas Médium 100W 4 Ohm Ø 15cm
Measurements
Technical specifications
Speaker driver typeMidbass
PowerRMS : 100W
Max : 200W
Sensitivity91dB/2.83V/1m
Impedance4 Ohm
DC Resistance3.2 Ohm
Resonance frequency59.4Hz
Total quality coefficient (Qts)0.53
Electric quality coefficient (Qes)0.56
Mechanical quality coefficient (Qms)11.72
Mechanical compliance of suspension (Cms)0.64mm/N
Diaphragm mass inc. airload(Mms)11.2g
Compliance equivalent volume (Vas)9.2l
BL product (Bl)4.9N/A
Voice coil inductance (Le)0.24mH
Surface area of cone (Sd)104.9cm²
Voice coil diameter25mm
Voice coil height15mm
Air-gap height6mm
Flux density10600 gauss
Linear excursion+/- 6mm
Max linear excursion+/- 11mm
Recommended roll off frequency2500Hz
Speaker Power (W RMS)100.0
Speaker TypeMidbass
Impedance (Ω)4
Loudspeaker diameter (mm)150.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)91.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
The LD150CR04 from Atohm is a low midrange speaker. It has been designed to produce high quality 2-way systems. Its design incorporates many Made...
