DAYTON AUDIO ES180TiA-8 Esoteric Series Woofer Speaker 8 Ohm Ø17cm
A midrange bass driver with great bass accuracy and an excellent response in midrange. An ideal candidate for a crossover setup with a speaker dedicated to high frequencies to obtain a high quality sound system. Accessible to beginners who want to work with high quality materials right away.
Reference : 12639
185,00 €tax incl.
154,17 € tax excl.
High quality Mid Bass Speaker ES180TiA-8
The speaker ES180TiA-8 front view
The Esoteric Dayton Audio series brings together expertise and advanced materials to achieve a highly qualitative result with excellent durability.
All its design , all the parts and their interactions have been worked with the most modern methods, by applying the Klippel and FEA optimizations.
The resistor is constructed from a copper-clad aluminum wire. It follows a flat coil structure (Edgewound) to form a conductor having a suitable density to a higher audio experience. The titanium structure ensures excellent transmission of the motor movement while enjoying an exceptional resistance to deformation. The dome is designed with fiberglass to easily withstand the high pressure exerted by the motor.
FEA Design & Klippel Optimization
The speaker enjoys a very precise design, an in-depth work to master the constraints to obtain a pure and powerful sound. It works with a neodymium motor optimized by FEA (finite element method) reinforced by two brass rings which drastically limit the amount of distortion by reducing the inductance during movement.
With its wide acoustic coil of 7.62 cm coupled to a titanium structure, the ES180TiA-8 is capable of rotating at high power while maintaining a superior transient response.
Advanced construction and its carefully selected materials ensure him an advantageous bandwidth that surpasses ordinary performance speakers of this size.
specifications
Nominal diameter17 cm
PowerMax: 200
RMS: 100 watts
Impedance8 ohms
Frequency response35-5500 Hz
Sensitivity84.8db 2.83V / 1m
Nominal diameter7.62 cm
mechanical Q4.9
Electronic Q0.44
Total Q0.4
Compliance mechanical suspension4.9
Mass of diaphragm (including air)26.8 g
inductance coil1.13 mh
Dimensions175 x 74.3 x 148.3 mm
Weight1.3 kg
Speaker Power (W RMS)100.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)170.0
Diaphragm typeGlass fiber
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)5.3
Lowest frequency (Hz)35
Highest frequency (Hz)5500
Download
DAYTON AUDIO ES180TiA-8 Esoteric Series Speaker Driver Midbass 100W 8 Ohm 85dB 35Hz - 5500Hz Ø17cm
A midrange bass driver with great bass accuracy and an excellent response in midrange. An ideal candidate for a crossover setup with a speaker...
