DAYTON AUDIO PC105-4 Full Range Speaker Driver
With the PC105-4, Dayton Audio unveils a full-range speaker driver with a compact form factor and 40Wrms power handling. This speaker delivers smooth, natural sound reproduction. It is ideal for DIY construction or repair of small audio systems, or as a building block for more complex assemblies requiring several drivers of the same type.
Reference : 19216
20,90 €tax incl.
17,42 € tax excl.
Shipping date: 09-04-2026.
Grantie 5 ans
DAYTON AUDIO PC105-4 Full Range Speaker Driver 40W 4 Ohm 90.3dB 80Hz-15kHz Ø12.6cm
Photo of DAYTON AUDIO PC105-4 speaker driver
With the PC105-4, Dayton Audio unveils full-range speaker driver with a compact form factor and 40Wrms power handling. This speaker delivers smooth, natural sound reproduction. It is ideal for DIY construction or repair of small audio systems, or as a building block for more complex assemblies requiring several drivers of the same type. Despite its small size, the PC105-4 4" delivers good sound reproduction and is suitable for a wide range of uses. It performs well when used as a midrange driver in a three-speaker system. It can also be used in the design/repair of portable speakers, line arrays, soundbars or any other configuration requiring speaker networking.
Here are some of the highlights of the Dayton Audio PC105-4:
  • Poly-damped woven fiberglass cone.
  • Copper cap maintains inductance and extends frequency response.
  • 25.4mm ventilated aluminum voice coil for high power handling.
  • High-energy ferrite magnet for high efficiency and performance.
  • Harmonious frequency response over a wide soundstage (ideal for single-HP systems).
Dimensions and measurements of the DAYTON AUDIO PC105-4 speaker driver
Product typeFull-range speaker driver
Power handling40Wrms
80W max.
Impedance4 ohm
Frequency response80Hz-15kHz
Sensibility90.3dB 2,.3V/1 m
Nominal diameter10.16cm (4")
Bolt Circle Diameter11.3cm (4.45")
Voice coil diameter2.54cm (1")
Depth5.99cm (2.36")
Mounting holes4
thiele-small parameters
Resonant Frequency (Fs)81.4Hz
DC resistance (Re)3.3 ohm
Voice Coil Inductance (Le)0.32mH
Mechanical Q (Qms)2.17
Electromagnetic Q (Qes)0.67
Total Q (Qts)0.51
Compliance Equivalent Volume (Vas)0.13ft³
Mechanical Compliance of Suspension (cms)0.92mm/N
BL Product (BL)3.3T·m
Diaphragm Mass Inc. Airload (Mms)4.2g
Maximum Linear Excursion (Xmas)2mm
Surface Area of Cone (Sd)52.8cm²
Materials of construction
Cone MaterialPoly-composite
Surround MaterialCaoutchouc
Voice Coil Wire MaterialCCA
Voice Coil FormerAluminium
Basket / Frame MaterialAcier
Magnet MaterialFerrite
Recommended enclosure volume
Sealed Volume0.07ft³
Sealed F3136Hz
Vented Volume0.15ft³
Vented F380Hz
Package1x DAYTON AUDIO PC105-4 speaker driver
Speaker Power (W RMS)40.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)107.0
Diaphragm typeComposite alloy
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)80
Highest frequency (Hz)15000
Dynamite dynamique !
Ce petit HP, dans la boite qu'il faut, est une bombe. J'avais besoin de petites boites pour du complément du monitoring principal, pour surveiller les médiums (vois, guitarre etc etc...), des Auratones fait maison en quelque sorte, mais avec une boite un peu plus grande j'ai deux fois mieux.
This review has been posted for DAYTON AUDIO PC105-4 Full Range Speaker Driver 40W 4 Ohm 90.3dB 80Hz-15kHz Ø12.6cm
With the PC105-4, Dayton Audio unveils a full-range speaker driver with a compact form factor and 40Wrms power handling. This speaker delivers...
