DAYTON AUDIO PS95-8 Speaker Driver Full Range 10W 8 Ohm 86dB 110Hz - 20kHz Ø9cm
The Dayton Audio PS95-8 is a full-range speaker from the brand's Point Source range. It features a curved cone made of lightweight paper, 100% natural fibers. The result is dynamic sound reproduction ranging from punchy bass to very high treble. In fact, this Dayton Audio PS95-8 loudspeaker covers the entire sound spectrum.
4.4 / 5
Reference : 9309
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 10-04-2026.
Grantie 5 ans
DAYTON AUDIO PS95-8
The Dayton Audio PS95-8 is a full-range loudspeaker from the brand's Point Source range. It features a curved cone made of 100% natural fibers. This results in dynamic sound reproduction ranging from punchy bass to very high treble, which is the very special feature of this Dayton audio PS95-8 loudspeaker; producing both articulate, balanced bass and midrange, as well as extended treble. In addition, the copper cap reduces inductance and distortion. This loudspeaker has a power handling of 10W for 8 ohms and an extended frequency response from 110Hz to 20kHz. Its compact size allows it to be easily integrated into small satellite desktop speakers or narrow "needle" style loudspeaker towers for ultra-high performance.
This Dayton Audio PS95-8 loudspeaker covers the entire sound spectrum, including clear, natural, detailed highs. That's why the addition of a tweeter isn't necessarily necessary when using the PS95-8.
KEY POINTS:
  • Detailed, natural audio performance throughout the entire range, without distortion.
  • Elegant anodized copper phase plug distributes dispersion and prevents resonance.
  • Low-mass voice coil and paper cone produce detailed sound that's not fatiguing to the ear.
  • The non-resonant molded frame enhances clarity and dynamics.
  • Copper motor pole caps reduce inductance and distortion.
Product typeSpeaker driver full range
Nominal output power (RMS)10W
Max. output power (max)20W
Impedance8Ω
Fréquency response110Hz à 20kHz
Sensibility85.56dB 2.83V/1 m
Voice coil diameter20mm
Resonant frequency (FS)119.8Hz
DC resistance (Re)7.1Ω
Voice coil inductance (Le)0.63 mH @1kHz
Mechanical Q (Qms)7.33
Electromagnetic Q (Qes)0.8
Total Q (Qts)0.72
Compliance equivalent volume (Vas)0.03 pi³
Mechanical suspension compliance (Cms)0.79mm/N
BL Product (BL)3.83Tm
Diaphragm Mass Inc. Airload (MMS)2.2g
Maximum linear excursion (Xmax)2.5mm
Cone surface (Sd)28.3cm²
Cone / diaphragm materialPolypropylene
Surround materialCaoutchouc
Voice coil wire materialCopper
Acoustic coilKapton® / Polyimide
Frame materialCast aluminium
MagnetFerrite
Overall outside diameter76.8mm
Baffle cutout diameter69.8mm
Overall depth52.3mm
Mounting holes4
Package1x Dayton Audio PS95-8 full-range speaker driver
Speaker Power (W RMS)10.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)90.0
Diaphragm typePolypropylene
Efficiency / Sensitivity (dB)83.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)110
Highest frequency (Hz)20000
5 reviews
Excellent
Parfait, mis dans une sphère imprimée en 3D, excellent résultat audio.
This review has been posted for DAYTON AUDIO PS95-8 Speaker Driver Full Range 10W 8 Ohm 86dB 110Hz - 20kHz Ø9cm
Woofer full range efficaces
Woofer efficace pour mon premier projet. Je n'ai pas fait de crossover pour cet essai mais il mérite une légère atténuation des mediums (dans mon cas) et une augmentation des graves. (baffle step).
Je recommande pour les débutants dans mon cas !
Good
Good sound for the price but a littel bit flat. They don't have a big soundstage. WIthe a few € more you can get way better speaker.
très bon HP
Très bon HP large bande qui font très bien leur job dans des enceintes diy pour le bureau. De beaux médiums, un aigu pas du tout brillant, pour les basses et bien c'est un petit large bande et pas des woofers de 30 cm. Je suis ravi.
Excellent
Excellent petit HP le son est vraiment très réaliste et jamais agressif j'ai fait plusieurs petites enceinte bluetooth avec ,ils fonctionnent très bien en BR dans un volume d'environ 4 litres avec un event de 35/110.
Rapport qualité prix au top
 (3)
The Dayton Audio PS95-8 is a full-range speaker from the brand's Point Source range. It features a curved cone made of lightweight paper, 100%...
