FOUNTEK FE87 Broadband Speaker 7cm
This small, high-quality speaker is ideal for small and medium-sized speakers. Here is an ideal speaker for satellite monitor design without tweeter for a consistent and affordable result. With its 8 ohm impedance, it can be use MTM medium medium tweeter mode or with several speakers for a wide range of broadcast (Line Array).
Asubwoofer can provide better support in bass from 100Hz for a perfect fit in a 2.1 system.
Specifications | Magnet system | ||
Overall Dimensions | 79X79X52.7mm | Magnet system type | ferrite shield |
Net.Weight | 0.56 kgs | Magnetic Gap Height | 3mm |
Nominal Power Handlng | 13 W rms | B Flux Density | 1.03T |
Nominal Impedance | 8 Ohms | Bl Product | 3.1Tm |
Sensitivity 1W / 1M | 84dB | Max Linear Excursion | 1mm+/- |
Frequency Response | 100-25,000Hz | T / S Parameter | |
Resonant frequency | 101Hz | cms | 1.181mm/NOT |
Voice Coil | sd | 27.34cm^ 2 | |
Voice Coil Diameter | 25mm | Vas | 1.254L |
Voice Coil Height | 5mm | Mmd | 1.991gm |
Voice Coil Former | Black aluminum | mms | 2.073gm |
Voice Coil Wire | copper round | qms | 3381 |
Number of Layers | 2 | Qes | 0939 |
DC Resistance | 6.776 Ohms | qt | 0735 |
| Speaker Power (W RMS) | 13.0 |
| Speaker Type | Full range |
| Impedance (Ω) | 8 |
| Loudspeaker diameter (mm) | 80.0 |
| Diaphragm type | Aluminium |
| Efficiency / Sensitivity (dB) | 84.0 |
| Max Linear Excursion (Xmax) (mm) | 1.0 |
| Lowest frequency (Hz) | 100 |
| Highest frequency (Hz) | 25000 |
Average votes 3.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Etienne M.
Etienne M.
