MONACOR SPH-135 / AD Speaker Driver Midbass 60W 8 Ohm Ø13cm
Reference : 826
48,70 €tax incl.
40,58 € tax excl.
60 W MAX , 8 Ω Hi-Fi Bass-Stereo Speaker
Carbon fiber membrane, long life rubber suspension, Kapton support, flat wire technology, oversized magnet, kernel decompression. For 2-way systems, close or bass-reflex load, decorative crown.
 yl = "font-family: Verdana; font-size: small;">
 Impedance (Z) 8 Ω
 Fresonance frequency (fs) 39 Hz
 Maximum bandwidth f3-6000 Hz
 Freq. cut. (fmax). 5000 Hz
 Maximum power 60 W MAX
 Rated power (P) 40 W RMS
 Pressure sound. (1W / 1m) 89 dB
 Compliance susp. (Cms) 2.14 mm / N
 Moving mass (Mms) 7.8 g
 Mechanical resistance (Rms) 0.6 kg / s
 Mechanical overvoltage. (Qms) 3.40
 Electrical overvoltage (Qes) 0.42
 Fact. total surge (Qts) 0.37
 Volume equ. (VAS) 26 l
 DC resistance. (Re) 5.5 Ω
 Inductance coil. (The) 0, 47 mH
 Coil diameter 25.5 mm
 Coil holder Kapton
 Height winding 9.5 mm
 Air gap height 6 mm
 Linear Excursion (X MAX ) ± 1.75 mm
 Transmitting surface (Sd) 95 cm 2
 Flight. air displaced (Vd) 16.6 cm 3
 Force factor (BxL) 5.0 Tm
 Ref. (No) 0.4%
 Magnet diameter 100 mm
 Magnet Weight 13.3 oz.
 cutting Ø 121 mm
  Mounting depth  70 mm
 Dimensions 135 x 135 mm
 Weight 1.1 kg
 Recommended Min Volume
 <img src = "http://www.monacor.com/global_img/blank.gif" alt = "" width = "10" height = "1" />
 closed 10 l
 bass reflex 22 l
PDF-Download
</ A>
PDF-Download
Speaker Power (W RMS)60.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)130.0
