MONACOR SPX-200WP Speaker Driver Full Range
The Monacor SPX-200WP full-range driver offers excellent sound quality, with a wide frequency response. It reveals a very slight accentuation in the high frequencies, with nevertheless deep bass reproduction. It features a low-resonance polypropylene cone and rubber suspension. Ideal for installation in a load-closed cabinet.
Reference : 19397
59,00 €tax incl.
49,17 € tax excl.
Shipping date: 07-04-2026.
Monacor SPX-200WP Speaker Driver Full Range 50W 8 Ohm 89dB 36Hz-18kHz Ø20.3cm
Monacor SPX-200WP loudspeaker
Monacor SPX-200WP: Dimensions and frequency response
Speaker driver typeFull range
Nominal diameterØ203mm
Power handlingRMS : 50W
Max : 400W
Impedance8Ω
Frequency response36Hz - 18000Hz
Sensitivity89dB
Voice coil diameterØ25mm
Weight1.32kg
Total external dimensionsØ203*89mm
Magnet weight564g
Thiele-Small parameters
Resonant frequency (fS)36Hz
DC resistance (RE)7.6Ω
Voice coil inductance (LE)0.35mH
Mechanical quality factor (QMS)4.18
Electrical quality factor (QES)0.69
Total quality factor (QTS)0.59
Equivalent volume to the compliance (VAS)60.5L
Compliance (CMS)950µm/N
force factor (B·l)6.79T·m
Mechanical resistance (RMS)1.07N·s/m
Moving mass (MMS)19.7g
Moving mass (without airload) (MMD)17.4g
Max linear excursion (XMAX)2mm
Air volume displaced at Xmax (VD)43cm³
Efficiency (η₀)-
Bandwidth efficiency (EBP)-
Effective area (SD)213cm²
Materials
DiaphragmPolypropylene
SurroundRubber
Voice coil wireKapton
Voice coil former-
Frame-
Magnet-
Mounting informations
Outer diameterØ203mm
Cutout diameterØ180mm
Depth89mm
Bolt circle diameter-
Number of mounting holes4
Speaker Power (W RMS)50.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)203.0
Diaphragm typePolypropylene
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)36
Highest frequency (Hz)18000
MONACOR SPX-200WP Speaker Driver Full Range 50W 8 Ohm 89dB 36Hz-18kHz Ø20.3cm
The Monacor SPX-200WP full-range driver offers excellent sound quality, with a wide frequency response. It reveals a very slight accentuation in...
