By buying this product you get 39 loyalty points
DAC & Headphone Amplifier
The HA-DSP is a brand new DAC / Headphone Amplifier of the brand MiniDSP. In addition to providing 3 inputs (USB / Analog / Toslink Optics), the HA-DSP provides digital audio processing power and unprecedented flexibility in a headphone amplifier.
Simple micro-bass and treble settings, 10 fully programmable EQ parameters per channel, and a FIR / Cross-Feed filter matrix that allows the installation of extremely sophisticated correction algorithms, this is what characterizes this MiniDSP headphone amplifier.
All this power is provided by a 500MHz XMOS multi-core processor and a 400MHz SHARC DSP. The embedded firmware is designed to have easy-to-use interface on laptops, desktops, iOS devices and Android.
Any other source can be connected via the analog input or
Any other source can be connected via the analog input orthe optical digital input. As for USB audio transmission, this HA-DSP supports both PCM and DSD formats.
Designed in a lightweight and compact package, this MiniDSP HA-DSP can follow you wherever you want. Its 3300maH battery offers enough power for a listening session of at least 10h.
The combination of MiniDSP technology, careful selection of each component, and a high-quality ESS SABRE ES9018K2M DAC 32Bit make HA-DSP an unprecedented headphone amplifier.
Following the comprehensive test Qobuz platform, the DSP Ha was awarded the Qobuzissime award for its excellent audio performance.
Read the test here.
| Connections: Inputs | |
| Micro USB | 1x |
| USB-A | 1x |
| 3.5mm Jack / Optical Digital | 1x |
| Connection: Output | |
| Jack 3.5mm | 1x |
| Specifications | |
| ADSP-21488 | DSP SHARC 400MHz |
| Asynchronous USB | XMOS Xcore200 multicore processor |
| DAC | ESS ES9017K2M |
| Audio Modes | PCM & DSD |
| Digital and analog inputs | |
| USB Type | 2.0 |
| Various | |
| Dimensions | 138 x 69 x 20mm |
| Color | Black |
| Housing | 100% Aluminum |
| Weight | 230g |
| Charge | via USB-A |
| Accessories | 1x USB-A cable to AC adapter, 1x micro USB to USB-A cable, 1x micro USB to micro cableUSB OTG, 1x 3.5mm Jack to 3.5mm Jack Cable, 1x Optical to 3.5mm Jack Adapter |
Read the test here.
| Micro USB | 1x |
| USB-A | 1x |
| Jack 3.5mm | 1x |
| Specifications | |
| USB Type | 2.0 |
| Various | |
| Color | Black |
| Weight | 230g |
