AIYIMA offers with the H1 a compact and powerful portable headphone amplifier. With an AUX input, it is an ideal companion for use with many devices; phone, computer, tablet, etc. It integrates a classic 3.5mm jack output compatible with the majority of your listening devices such as headphones or active speakers.
This headphone amplifier with these two OPA NE5532 chips reaches an output power of 170mW @ 32Ω .
If you want the OPA chips are easily replaceable.
The AIYIMA H1 comes with an 800 mAh battery that will allow you to enjoy 4 hours of listening. This battery is easily replaceable to improve the performance of this headphone amplifier.
The H1 charges via a USB-C port and has an input and output both in 3.5mm Jack. In addition, a volume control is also present and also serves as an on/off button.
| SpEcifications | |
| Product type | Portable headphone amplifier |
| OPA chips | 2x NE 5532 |
| Input | 1x Jack 3.5mm (AUX) |
| Ouput | 1x Jack 3.5mm |
| Output power | 170mW @ 32Ω |
| Frequency response | 20hz-20Khz (±0.1db) |
| SNR | ≥111db |
| Distorsion | 0.03% |
| Load impedance | 16-300Ω |
| Working voltage | 2.8V-4.2V |
| Charging voltage | DC5V (USB-C) |
| Battery capacity | 800mah (Lithium batterie) |
| Maximum volume working time | 4h |
| General | |
| Dimensions | 110 x 62 x 17mm |
| Net Weight | 123g |
| Gross weight | 210g |
| Color | Black |
| Package | 1x AIYIMA H1 1x USB-C to USB-A charging cable 1x 3.5mm jack to 3.5mm jack cable 1x Accessory tool set |
