Portable Headphone Amplifier DAC 2x ES9318 Bluetooth 5.0 32bit 768kHz DSD512
Aune offers with its BU2 an excellent headphone amplifier and portable DAC combo, benefiting from a beautiful design quality, with notably the use of two ES9318 DACs, a Bluetooth 5.0 chip or a R2R volume controller. This set ensures a sound restitution of a great precision and richness. Moreover, it benefits from a double output, with single-ended 3.5mm jack but also balanced 2.5mm jack.
The conversion stage of the Aune BU2 is based on a duo of ESS ES9318 digital/analog converters mounted in parallel for a precise and clear sound reproduction. The amplification stage embeds four independent headphone amplifiers. In addition, a low ripple positive/negative power supply is used to power all the circuits in an efficient way.
The Aune BU2 features next-generation Bluetooth 5.0, including support for the high-definition transmission codecs aptX and aptX HD. This makes it possible to easily stream music to the BU2 via a smartphone and computer, but also to connect the BU2 to headphones or Bluetooth headphones.
The BU2 also has a USB-C input. This one allows to enjoy files in very high resolution, up to PCM 32bit 768kHz andDSD512 for a sound restitution of an incredible quality.
The Aune BU2 uses two ultra low jitter clocks 45M and 49M, directly synchronized with the decoding chips, via the USB interface. These ensure a natural and transparent sound.
Intuitive and easy to use, the Aune BU2 uses a rotary encoder for quick access to all parameters and controls.
The BU2 adopts a dynamic volume control technology, consisting of an electronic switch and R2R resistors. These resistors allow to attenuate the volume level in a precise way, while maintaining an excellent SNR and a very good dynamic.
Product type | Portable headphone amplifier / DAC |
Inputs | Bluetooth 5.0 1x USB-C |
Outputs | 1x Balanced Jack 2.5mm 1x Single-ended Jack 3.5mm Bluetooth 5.0 |
Supported sampling rates | USB : PCM up to 32bit 768kHz, DSD up to DSD512 |
Output level | 1.8Vrms @ Jack 3.5mm 3.6Vrms @ Jack 2.5mm |
THD+N | 0.000145% |
SNR | -120dB |
Frequency response | 20Hz - 20kHz |
Output power | 265mW @ balanced Jack 2.5mm, 32Ω 100mW @ single-ended Jack 3.5mm, 32Ω |
Lifetime | 9h (USB decoding mode) |
Dimensions | 65 x 126 x 18mm |
Color | Black |
Package | 1x Aune BU2 1x USB charging cable 1x USB-C cable |
Input | USB |
Input | Bluetooth |
Output | Jack 2.5mm |
Output | Jack 3.5mm |
Output | Bluetooth |
Color | Black |
Class | N/A |
Remote Control | No |
