By buying this product you get 144 loyalty points
Shanling's Mystic XP1 is a state-of-the-art portable amplifier and DAC capable of converting signals up to PCM 32 bit 768kHz and DSD512. It has been designed to follow you everywhere and adapt to every situation, from driving small earphones when you're on the move to more demanding headphones for sedentary use.
The Mystic XP1 is based on a pair of AKM AK4499EX DAC chips combined with their AK4191 delta-sigma modulators for a conversion with formidable resolution and natural timbre. The amplifier stage benefits from a purely symmetrical design and is based on Texas Instrument's TPA6120A2 chip, specially optimised for headphone amplification. Furthermore, the balanced line output is equipped with an additional Muses8920 chip so that the Mystic XP1 can also act as a preamplifier. Finally, the whole package is completed by the 'Brighton' I/V conversion stage developed in-house by the brand.
Unlike other portable DACs that rely entirely on smartphones or computers to supply them with data, the Mystic XP1 has a Micro SD card slot, allowing lossless playback of all your files. So you can play your files directly from the Mystic XP1 or connect to them via the Eddict Player app for Android and iOS.
You can also connect the Mystic XP1 to your smartphones or computers via its high-performance XMOS XU316 USB input, or opt for the convenience of a wireless connection via Bluetooth 5.0, with support for LDAC, aptX HD and AAC. To connect it to your traditional HiFi equipment, the Mystic XP1 is also equipped with a SPDIF Mini-Toslink / coaxial combo input.
For sedentary use, connect the Mystic XP1 to its external power supply to significantly increase its output power. Offering up to 2360 mW at 32Ω and 480 mW at 300Ω in this configuration, the Mystic XP1 can easily drive the most demanding headphones on the market, making it a solid companion in any situation.
The Mystic XP1 closely follows the design of the ONIX Miracle, adopting elements of the classic ONIX look for this new generation of devices. Carefully CNC machined from high-grade aluminium, the unibody construction is both strong and beautiful, especially when combined with the gold-plated volume dial and retro-style dot-matrix OLED display.
Product type | Portable headphone amplifier and DAC |
Amplification chips | TPA6120A2 MUSES8920 |
DAC chip | 2x AK4499EX |
USB interface | XMOS XU316 |
Inputs | 1x SPDIF Coaxial / Optical Mini-Toslink combo input 1x Jack 3.5mm 1x USB-C 1x MicroSD Bluetooth |
Outputs | 1x Balanced 4.4 mm Jack line output 1x Balanced 4.4 mm Jack headphone output 1x Single-ended 3.5mm >Jack headphone output 1x Single-ended 6.5mm jack headphone output |
Bluetooth | 5.0 |
Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 |
Supported Bluetooth codecs | LDAC / aptX HD / aptX / SBC / AAC |
Gain levels | 2x 3 levels (earphone mode and headphone mode) |
Battery | 7000mAh |
Autonomy | Up to 10h |
Output power | Single-ended: 2.6V @ 32Ω THD+N ≤ 0.023% Single-ended with external power supply: 5.1V @ 32Ω THD+N ≤ 1% Balanced: 4.9V @ 32Ω THD+N ≤ 0.01% Balanced with external power supply: 8.7V @ 32Ω THD+N ≤ 1% |
Output impedance | 4.7Ω |
Frequency response | 20Hz-40kHz (-0.5dB) |
Total harmonic distortion more noise (THD+N) | 0.0005% |
Dynamic range | 120dB |
Channel separation | 101dB |
Signal-to-noise ratio | 120dB |
Dimensions | 160 x 92 x 30mm |
Weight | 583g |
Color | Black |
Package | 1x Shanling Mystic XP1 1x Jack 3.5mm to coaxial cable 1x USB-C to USB-C cable 1x USB-A to USB-C cable |
Input | Bluetooth |
Input | Optical Mini-Toslink |
Input | USB |
Input | SPDIF |
Input | Micro SD |
Input | Jack 3.5mm |
Output | Jack 6.35mm |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
Color | Black |
Class | Class D / T |
Remote Control | No |
