By buying this product you get 54 loyalty points
The xDuoo XD05T portable DAC and headphone amplifier is a high-performance device where cutting-edge technology meets vintage. Indeed, it's based on the use of tubes machined in the 60s, coupled with transistors for its amplification circuitry, while the digital-to-analog conversion stage uses two ES9039Q2M DAC chips, an XMOS XU316 USB interface and an FPGA. This little jewel of hybrid technology is therefore able to drive headphones with impedances from 32Ω to 300Ω without difficulty, while offering a soft, warm texture. What's more, it supports high-resolution sampling rates up to PCM 32Bit 768kHz, DSD512 and MQA x8 via its USB-C input.
The XD05T also boasts full connectivity, with a coaxial / Mini-Toslink optical input, a 3.5mm jack auxiliary input/output, a balanced 4.4mm jack input/output and, of course, two single-ended 6.35mm jack and balanced 4.4mm jack headphone outputs. Added to this are a range of operating modes, allowing it to be used as a desktop DAC/headphone amplifier, as well as Bluetooth 5.1 functionality thanks to a Qualcomm QCC5125 chip for great versatility of use. In terms of appearance, xDuoo has chosen a green chassis and gold-colored details to highlight the vintage spirit of its device.
xDuoo has opted for authenticity by integrating tubes from a sixties production, offering a sound texture full of emotion, soft and warm, that will delight the most nostalgic. The use of these tubes also offers a wider dynamic range, greater than or equal to 116dB for the balanced 4.4mm jack headphone output and 114dB for the single-ended 6.35mm jack headphone output. The final sound reproduction is therefore rich in detail, immersive and provides a natural timbre.
As for the xDuoo XD05T's amplification stage, the tubes are then coupled to a pair of transistors providing the necessary signal power to drive a wide range of headphones or earphones. Indeed, on its balanced 4.4mm jack headphone output, the xDuoo XD05T is capable of delivering up to 1500mW at 32 ohm and 565mW at 300 ohm. As for the digital-to-analog conversion stage, it relies mainly on two ES9039Q2M DAC chips and an XMOS XU316 USB interface, enabling it to support high-resolution sampling rates up to PCM 32bit 768kHz and DSD512 via its USB-C input.
The xDuoo XD05T benefits from 3 gain settings, Turbo (L) perfect for IEMs, Turbo (M) for low-impedance headphones and Turbo (H) for high-impedance headphones. This allows it to adapt to a wide range of hardware configurations, and to deliver its best performance in all circumstances.
The xDuoo XD05T features a switch to boost the bass in the sound reproduction for users who want a more immersive experience. This can also be useful depending on the source used.
If you want to use the xDuoo XD05T in desktop mode, simply power it via its DC USB-C power port. Of course, it can also be used on the move, thanks to its internal 6000mAh battery, which provides excellent autonomy.
On one side of the xDuoo XD05T, there's a potentiometer for adjusting the output volume over 99 levels, for precise setting whether low or high volume is required.
| 1 | Single-ended Jack 6.35mm headphone output |
| 2 | Balanced Jack 4.4mm headphone output |
| 3 | Display |
| 4 | Power on |
| 5 | Turbo function |
| 6 | Bass boost function |
| 7 | DC power supply |
| 8 | Coaxial / Optical Mini Toslink input |
| 9 | Operating mode selection |
| 10 | USB-C input |
| 11 | Jack 3.5mm input/output |
| 12 | Jack 4.4mm input/output |
| Specifications | |
| Product type | Portable DAC headphone amplifier |
| DAC chip | ESS ES9039MSPRO |
| USB interface | XMOS XU316 |
| Bluetooth chip | QCC5125 |
| Inputs | 1x USB-C 1x Coaxial / Optical Mini Toslink 1x AUX input/output jack 3.5mm single-ended 1x AUX input/output jack 4.4mm balanced |
| Outputs | 1x Single-ended 6.35mm jack headphone output 1x Balanced 4.4mm jack headphone output 1x AUX input/output jack 3.5mm single-ended 1x AUX input/output jack 4.4mm balanced |
| Supported sample rates | PCM up to 32bit 768kHz, native DSD up to DSD512 and MQAx8 |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX LL, aptX HD, LDAC |
| OS compatibility | Windows, Linux, Mac OS, IOS, Android |
| Single-ended Jack 6.35mm headphone output | |
| Output power | 750mw @ 32 ohm (THD+N>5%) 83mW @ 300 ohm (THD+N>5%) |
| Output impedance | < 0.2 ohm |
| Peak voltage | 15Vp-p (Turbo) |
| Frequency response | 20Hz-20KHz (±0.5dB) |
| Crosstalk | ≥ 75dB |
| THD+N | 0.5% |
| SNR | ≥ 114dB |
| Balanced Jack 4.4mm headphone output | |
| Output power | 1500mw @ 32 ohm (THD+N>5%) 565mW @ 300 ohm (THD+N>5%) |
| Peak voltage | 26Vp-p (Turbo) |
| Frequency response | 20Hz-60KHz (±0.5dB) |
| Crosstalk | ≥ 105dB |
| THD+N | 0.5% |
| SNR | ≥ 116dB |
| Single-ended Jack 3.5mm AUX output | |
| Output level | 2.0Vrms |
| THD+N | 0.00065% |
| SNR | ≥ 120dB |
| Crosstalk | ≥ 100dB |
| Balanced Jack 4.4mm output | |
| Output level | 4.0Vrms |
| THD+N | 0.00065% |
| SNR | ≥ 124dB |
| General | |
| Power supply | 12V DC (desktop mode) or battery |
| Circuit protection | Overheating Overload DC protection |
| Battery | 3.7V / 6000mAh |
| Battery operating time | USB/SPDIF: 4h AUX: 4.5h |
| Charging time | 3.5h (fast charge) 10h (slow charge) |
| Dimensions | 168 x 78 x 23mm |
| Weight | 400g |
| Package | 1x xDuoo XD05T 2x USB-C to USB-C cable 1x USB-C to Lightning cable 1x USB-C to USB-A adapter 1x 3.5mm jack to 6.35mm jack adapter |
| Input | Jack 3.5mm |
| Input | Mini Toslink 3.5mm |
| Input | USB |
| Input | Jack 4.4mm |
| Output | Jack 3.5mm |
| Output | Jack 4.4mm |
| Output | Jack 6.35mm |
| DAC / ADC Chip | ES9039Q2M |
| Color | Green |
| Class | N/A |
| Networking | No |
| Remote Control | No |
