Pierre H.
4N ou 6N
Didier C.
Etonnante petite boite !
Didier C.
Customers reviews - There are 19354 reviews.
Martins R.
XANGSANE XS-DIY1 Pure Silver Wire 99.99% FEP 0.08mm² Ø0.62mm The Xangsane XS-DIY1 is a high-end cable with 99.99% pure silver as the conductive material. This ensures maximum electrical conductivity for optimal audio signal transmission....
Perfect headphone cable
This is a perfect cable for headphones eith just a bit of stiffness and microphonics. The sound quality though makes up for it completely. Best cable have ever heard for a headphone..
Martins R.
XANGSANE XS-DIY1 Pure Silver Wire 99.99% FEP Ø0.8mm The Xangsane XS-DIY1 is a high-end cable with 99.99% pure silver as the conductive material. This ensures maximum electrical conductivity for optimal audio signal transmission....
Perfect internal cable
Perfect for speaker internal externel wirering stiff
Martins R.
Awesome quality
Perfect silver cable for internal wires and speaker internal and external wirering. Sublime sound quality, astonishing quality of finish. Phenomenal performance for price, unbeatable bang for buck. Can not use for headphones to thick and stiff. Use the one doqn for headphones.
Martins R.
MUNDORF MCONNECT SGW105W PTFE Insulated Pure Silver / Gold Cable 0.5mm White This Mundorf MConnect SGW105W cable sold by the meter ensures excellent signal transmission thanks to its composition based on Silver mixed with 1% extremely pure Gold. In...
Best cable period
Simply put this is the best signla wire one could ever want, quite a nice step up from silver. With a lot more texture and clarity. Pretty stiff though, for using in internal wires works great, could not use this thicknes for a headphone cabl3
Martins R.
ATAUDIO AT-0T Jack 6.35mm TRS Connector Gold Plated Ø8mm Red This ATAudio AT-0T Jack 6.35mm TRS connector features a high quality design, ensuring both performance and durability. It features a rugged metal body and 24k gold-plated...
Fantastic quality
Very good quality 6.35mm jack. Gold plated contacs and solder tags. Easy to work with.
Martins R.
ATAUDIO AT-X10 Jack 3.5mm TRS Connector Gold Plated Ø6mm Blue This ATAudio AT-X10 Jack 3.5mm TRS connector features a high quality design, ensuring both performance and durability. It features a rugged metal body and 24k gold-plated...
Fantastic quality
Perfect 3.5mm jack for line in cables and desktop use. For hp cables and portable use a bit to thick. Super easy to solder and work with.
pascal P.
Excellent en liaison phono. Il enterre les câbles spécialisés renommés. Ce n'est peut-être pas pour rien que le gourou japonais Kadena l'utilise en phono...
Piotr K.
Neotech silver
Bought this out of curiosity to check how good it can be against established brands. I have build this Nei-2001 with Aeco silver plated XLR"s . I'm amazed how god it sounds. It's still new so it only get's better with burn in. It seems to be very detailed and articulate, air around instruments is very nice. Sound seems to be denser more defined and most importantly very! engaging.. I like it a lot ,it's way better than my previous reference XlLR (which was for years nordost quatro fil )
Didier T.
Une valeur sûre pour mélomanes, sans se ruiner
Utilisateur de Titanex 3G2.5 (sur recommandation de FIRODIL) de longue date, celui-ci propose des résultats assez chaleureux et articulés pour un prix dérisoire.
S'il n'est pas du genre à donner envie de couper les décibels en 4 ni à se pâmer "audiophilement" devant son grave, son medium ou son aigue, la cohérence mélomane qu'il procure est tout bonnement exemplaire à ce prix.
On pourra toujours pinailler ici sur plus d'aération ou là sur moins de coquetterie dans la charnière haut medium/aigüe, mais je le suspecte d'être sacrément plus homogène, plein et naturel que nombre de câbles dédiés à l'audio qui fleurissent ça et là y compris à des tarifs sensiblement supérieurs.
Et compte-tenu du sérieux d'Audiophonics, s'ils le propose, c'est qu'il y bel et bien une raison...
Bref, troquer les câbles basiques d'origine par ce Titanex 2G2.5 ne se discute pas...
Juan M.
AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Black The X8 XVIII BT Magic DAC from Aune is a special edition of the DAC, on the occasion of the 18th anniversary of the brand. This one takes back the idea of the interchangeable...
DAC with sparkos ss2590
This dac for the price is wonderful, I bought it and directly installed the operational sparkos SS2590 Pro. The sound is simply perfect, I couldn't imagine it better. Airy, clear, musical, with an impressive dynamics. I recommend 100% the update with SS2590 Pro. Warning, you need to buy a small elevalor for the chip, otherwise it touches the case, and then put some higher feet.
Gonçalo P.
MOGAMI NEGLEX W2549, That's OK
Regarding the item purchased, the material is what was expected. Regarding shipping, it should be noted that the shipping carrier provided a service well below average, with a day delay compared to what they themselves sent as alert. I strongly advise you to change your shipping service
3E AUDIO 480-1-29A PFFB Mono Balanced Class D Amplifier Module TPA3255 1x480W 2 Ohm This 3E Audio 480-1-29A amplifier module is a class-D balanced mono amplifier module based on a TI TPA3255 chip. This module delivers up to 480W into 2 Ohm (@ 1% THD+N, 1kHz)...
Excellent, 3 fois deux !
une paire de blocs mono réalisée avec ces modules: résultat magnifque , très musical . encore meilleur que le module stéréo (déjà excellent) du même fabricant. c'est peu dire!
adrien n.
Super ampli
Au niveau son, rien à dire, il fait le job pour une utilisation streaming à partir d'un PC (Tidal, chaînes TV sur internet...). La puissance est suffisante pour mes petites enveintes colonne Triangle.
Mais ce qui est bluffant avec cet appareil c'est sa simplicité d'utilisation. En deux temps trois mouvement tout fonctionne, notamment l'appariement bluetooth avec tablettes et baladeurs. Par comparaison j'ai acheté un Wiim amp qui a un très bon son également mais qui m'a causé des maux de tête tant l'application est compliquée à utiliser.
Pareil au niveau design, c'est hyper sobre et ergonomique. Adieu la brique d'alimentation à découpage, le DAC séparé... On pose sur le bureau, on branche et c'est ti-par !
J'ai relevé deux petites imperfections qu'on lui pardonne volontiers : 1) il semble impossible d'éteindre l'éclairage (très puissant, et blanc contrairement à la photo 2) l'entrée USB marche mais il faut sélectionner l'entrée BT au lieu de US.
Au final, super appareil, je ne regrette pas du tout cet achat, bravo à l'atelier Audiophonics qui est compétitif par rapport aux marques chinoises. On attend les mesures sur Audio Science Reviews avec impatience !
SERGE B.
Mal concue
Cette prise Schuko est très mal conçue. Il n'y a en effet que très peu de place pour faire passer les fils à coté de l'emplacement de la vis centrale. Ne peut à la rigueur convenir que pour du câble de faible diamètre. Par ailleurs, la fixation du fil de terre est très mal fait.
A éviter
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 12V 1A 25VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
super génial
Produit top la classe qualité sonore l'image incroyable vue rapport qualité prix rien à dire compatible sfr zeop orange
netflix 5 étoile bon matos 2024 merci
Philippe E.
EVERSOLO BTR-12 IR / Bluetooth Remote Control for DMP-A6 / DMP-A6 Master / DMP-A6 Gen 2 / DMP-A6 Master Gen 2 This IR / Bluetooth BTR-12 remote control developed by Eversolo is designed to be paired with all their DMP series devices, i.e. the DMP-A6, DMP-A6 Master Edition, DMP-A6 Gen 2,...
La télécommande BTR-12 est très fonctionnelle, elle permet de ne pas être connecté en permanence sur son mobile pour tout faire dans l'utilisation du DMP-A6. Au passage, ce lecteur réseau est également excellent et possède plusieurs réglages qui optimisent encore la retranscription de la musique.
SERGE B.
Très bons embouts à sertir pour protéger les extémités de fils ou câbles de cuivre
SERGE B.
Excellente qualité
Chers mais d'excellente qualité pour protéger les embouts de câbles de qualité.
SERGE B.
Excellente qualité
Bien finis et très utiles pour protéger les embouts de câbles.
SERGE B.
24k Gold-Plated Copper Spade Ø4mm (Unit) This robust spade is made from copper and is 24k gold-plated, giving it high conductivity and resistance to corrosion and oxidation. It features...
Très bonnes fourches en cuivre OFC 4N comme il se doit et plaquées or. La longueur du corps est suffisante et le système de serrage du câble à deux vis est parfait. Je sertis les extrémités des câbles avec des cosses en cuivre plaquées or également ce qui facilite leur introduction et évite de casser des fils.
Inutile de payer plus cher à moins d'avoir du câble plus gros.
SERGE B.
Excellente qualité
Excellentes fourches assez épaisses en cuivre OFC 4N comme il ses doit et plaquées or. La longueur du corps est suffisa systèmede
Michael L.
O-NOORUS PA-316 Amplifier Class D 2x TPA3116D2 Bluetooth 5.0 2x60W 4 Ohm This small, compact, versatile and high-performance O-Noorus PA-316 Class D amplifier incorporates two TI TPA3116D2 amplifier chips, each dedicated to one channel. It is thus...
Not perfect but good for the low price
My pa-316 just arrived
long press volume to turn it on,off short input selection (no aut bt) no pop sound turning it on,off
loose volume knob, like a steering wheel that only make the car turn after half an inch (hate it)
tone controls off neutral sound, clean sound even at max volume, above 12 o'clcok if you want it loud (volume better on a Fosi audio bt 20a), the difference on the volume from 12 o'clock to max is to big or not big enough how you interprest it (medium to loud from 12 to 2 o'clock) + a good bass
Gets varm playing loud (not alarming), a Fosi Audi bt20a don't get warm, 24v 6.75 psu instead of 24volt 4.5 a as some amps has
Usb works but no driver to change samplerate and to se what samplerate is used
Pierre-Marin L.
Je vais continuer la litanie des gens satisfaits : ce cable remplace un cable I2S couteux, et sur mon Holo Red vers mon Holo Spring le résultat est bien meilleur ! Pour un prix avantageux
Merci Audiophonics !
Deividas S.
Stéphane M.
2ème commande de ce produit magique
Tellement efficace et pas cher pour un nouvel usage et encore un exploit un terme d'efficacité tout comme Audiophonics ! commandé et réceptionné en 5 jours malgré un jour férié vers l'île de la Réunion. Un site vendeur exceptionnel.
voir ici le changement que produit ces isolants sur ma barre ambeo plus et Q Acoustics 3060s (remarquez la finesse de 1khz à 20khz) gain en clarté et spatialisation : https://i.postimg.cc/hP9rNS8M/Effet-sorbothane.jpg
bon rqp
Solide pas de perte audible prix correct.
Male Jack 6.35mm to Male Jack 6.35mm Stereo Cable Shielded Gold Plated 2m This double jack 6.35mm stereo cable features a pure copper core for maximum conductivity. The core is shielded by an aluminum foil combined with a copper alloy weave to ensure...
bon rqp
Aucune perte audible prix correct
Parfait, mis dans une sphère imprimée en 3D, excellent résultat audio.
Neutre
Très bon RQP.
Sebastien S.
TOPPING DX9 DAC AK4499EQ Headphone Amplifier NFCA Bluetooth 5.1 AptX LDAC 32bit 768kHz DSD512 Black To celebrate its 15th anniversary, Topping unveils a high-performance DAC / Headphone Amplifier: the DX9. In addition to its very high performance, Topping has given it a...
La musique prend de la vie avec ce DAC
J'ai remplacer mon intégré Cyrus 8 qui ne donne plus de dynamisme , ce préamp Dac redonne la vie à la musique, sur un ampli vintage DENON PMA 501 double transfo. J'ai connecté un lecteur CD mais cela ne fonctionne pas, faut-il un lecteur transport uniquement ? Merci pour votre réponse.
Eric D.
Enfin satisfait
J’ai acheté ce dac ampli casque pour pouvoir exploiter min recent achat d’un casque moondrop para sur ce même site. Ce dernier sous 08ohms manquait cruellement de volume connecté à mon littledot mk2.
Aujourd’hui, totale satisfaction la puissance 3watts sous 16 ohms est parfaite pour mon casque.
Je découvre le dac et envisage un abonnement pour exploiter ses capacités au delà du mp3 et aac.
Merci à audiophonics pour l’expédition rapide et l’emballage serieux.
Benoit d.
Bien mais petit défaut
Conforme et bien construit. Les barettes de connexions pour bicablage sont simple a démonter. Mais pour mon usage il y a un défaut : les borniers dépassent du cadre même vissés complètement alors que je voulais qu'ils soint protégés pour le transport de l'enceinte.
Benoit d.
Nettoie parfaitement le bruit parasite qui venait de la connections de 2 amplis sur une même source
bernard g.
pince très fine passe partout parfait
bernard g.
CWS1 3-in-1 Cutting / Stripping / Cramping Pliers The CWS1 3-in-1 pliers have 3 functions. It will enable you to cut, strip and crimp cables.
trés bonne pince
bernard g.
collier parfait pour travaux délicat
bernard g.
ATAUDIO SNOW SLEEK Balanced Signal Cable Silver Plated OCC Copper Ø8mm This balanced modulation cable sold by the meter consists of 12 silver plated OCC copper wires individually insulated with a PTFE sleeve. It ensures an excellent conductivity...
cable secteur
une fois assemblé les 3 cables et les connecteurs krell de très bonne qualité après un essai le résultat est surprenant avec une section de 6mm2 les cables sont croisés ensemble
le cable secteur est entre la prise murale plaqué rodium et les barrettes shuko la musique a gagné en dynamique et est très bonne surtout avec une riche de détaille des basses très naturelle et des aigus limpide et des médium incroyable
attention tous a été optimisé les cables secteur sont tous de hautes qualités ampli casque a tube casque éléctrostatique haut de gamme et lecteur cd haute qualité fiches xlr haute qualité musicalement ce cable est le meilleur que j ai bernard
Charles B.
TOPPING DX3 PRO+ DAC ES9038Q2M NFCA Headphone Amplifier Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Silver Topping unveils its DX3Pro+, a direct evolution of the excellent DX3Pro, an excellent compact DAC also offering headphone amplification and preamplification functions. Embarking...
Produit livré rapidement et parfaitement emballé . Ce site est très sérieux et hautement recommandable . Le Topping DX3 pro + , offre pour moins de 200€ d’excellentes prestations . Sous un format compacte on trouve un préamplificateur un Dac et un très bon amplificateur casque , il drive actuellement mon Focal Elear sans problème. La construction respire le sérieux et la solidité , et son écran est utile et visible de loin , le gros plus dans cette gamme tarifaire est la …. Télécommande , vraiment appréciable ( toutes les fonctions de l’appareil s’y retrouvent ) . Je pense que l’ajout d’une bonne alimentation linéaire améliorerait d’avantage cet appareil . Même en rodage il a une excellente musicalité . Je recommande vivement ce produit qui pour cette somme , a un RQP exceptionnel.
TINYSINE TSA9840B Class D Mono Amplifier Module MAX98400A Bluetooth aptX TWS 20W 8 Ohm The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, allowing to deliver, in this mono version, a power of 20W. This module can then...
Parfait. Résultat excellent avec un petit Hp Dayton 95-8.
DC 5V Jack Filter with Supercapacitor to Jack DC This DC 5V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 20F - 3.0V and an...
Superbe amélioration du résultat Audio
Je connaissais les SC mais j'hésitais de les utiliser a cause de la très forte demande en courant au démarrage, ce "petit" par la taille améliore fortement le résultat audio lorsqu'une alim linéaire ou découpage est utilisée.
J'en possède maintenant 3 dont deux 5 volts sur streamer et Dac la troisième sera utilisée plus tard sur alim du Nas.
N'hésitez pas une seconde le rendu audio passe un gap énorme avec l'ajout de ces super condensateurs.
Christian S.
Best price-performance ratio!
Professional 75 ohm cables are all you need to transmit digital audio data. The Canare RCA plugs fit like a glove and are perfectly pressed onto the cable. For a RG6 cable with a diameter of 7,7 mm it is very flexible and easy to handle...
Laurent D.
Shanling confirme le défaut de la non prise en charge du gapless entre les pistes musicales.
Pas de corrections prévues pour le moment. Cette fonctionnalité n'est utilisable que pour les pistes sur microSD.
https://www.head-fi.org/threads/introducing-shanling-ec-mini-transportable-cd-player-dap.969879/post-17936483
Ammar j.
Excellent amplifier
Small, lightweight, clean power into any reasonable impedance, at a great price.
Martin A.
The name says it Hi End and the cable really is. Everything seems more mature more believable with this cable. And the impression is already straight out of the box. After some running things improve massively. Things like depth air positioning of different sources of sound on the stage are all there like the better and costly power cords do. Replaced an already good Qed ethernet that is like comparing midrange vs high end. Used between cisco 2960 and Gustard r26
Robert G.
BURSON AUDIO V7 CLASSIC PRO Dual OPA (Unit) As an evolution of the V6 Classic, the V7 Classic Pro now achieves ultra-low noise levels while retaining the sparkling highs that are the strength of its predecessor. Overall,...
Awesome upgrade from SS3602
Coming from the Sparkos the first thing i noticed was the huge stage.
The Classic is a bit more mid-focused which can be a bit much depending on your gear you listen on.
The Vivid on the other hand is the neutral sibling which shares the same spatial advantages over the Sparkos but keeps the same tonality, first thing i noticed with the Vivid was how clean everything sounded.
TLDR: Classic - mid emphasis (yum) Vivid - neutral
Philippe S.
Respire la qualité furutech
Voir mon avis pour la prise mâle.
Philippe S.
Oui, c'est un produit qui n'est pas bon marché mais j'ai gagné en clarté par rapport aux fiches 701 et 702, si vous le pouvez, n'hésitez pas à changer.
Paul D.
Petit mais quels résultats impressionnants
Cela fait quelques mois que je possède le SMSL PL 200, et il s’est progressivement affirmé!
La musique s’exprime d’une façon naturelle, en largeur et profondeur. Les sons, la définition,
la musicalité, sont d’un naturel surprenant, je me suis remis à écouter mes CD et ma musique
pendant plusieurs heures, alors que précédemment à mon achat j’étais resté moins attiré par mes écoutes! Formidable appareil!
adrien b.
Récepteur performant et pratique
Je suis très satisfait de cet appareil, que j'ai acheté pour rajouter le BlueTooth sur une ancienne chaîne haute fidélité :
Le son est impeccable ;
L'appareil est "plug and play", tout de suite reconnu ;
Pas de perte de connexion, même avec l'antenne courte ;
Boîtier robuste, connectiques de qualité et construction sérieuse ;
Le prix !
Alain M.
Excellence audio
J'étais à la recherche d'un petit module audio pour multi-amplifier mon enceinte, une Jalucine 24.
Puis, je suis tombé sur ce module dont Audio Science Review (et d'autres) disaient le plus grand bien.
Pour l'alimenter j'ai eu recours à une SMPS Connex de 36V/300W.
A la première mise sous tension, le son était très sale (râpeux, distordu), limité dans les aigus. Un peu déçu. Puis, je l'ai laissé sous tension toute la nuit, et je n'ai plus reconnu le son que j'avais la veille, beaucoup plus fin, mieux défini.
Au troisième jour, le son est parfait (comparé à un Super 30W Classe A Hiraga), du grave à l'aigu.
Je recommande donc sans réserve.
