Bass-midrange speaker, 100 W MAX , 8 Ω Specially coated paper membrane, rubber suspension, optimized aluminum bowl, the ideal speaker for 2-way systems. | |||||
Speakers Speakers | |||
![]() | Impedance (Z) | ![]() | 8 Ω |
![]() | Resonance frequency (fs) | ![]() | 33 Hz |
![]() | Maximum bandwidth | ![]() | f3-5000 Hz |
![]() | Freq. cut. (fmax). | ![]() | 3000 Hz |
![]() | Maximum Power | ![]() | 100 W MAX |
![]() | Rated power (P) | ![]() | 60 W RMS |
![]() | Pressure sound. (1W / 1m) | ![]() | 90 dB |
![]() | Compliance susp. (Cms) | ![]() | 1.86 mm / N |
![]() | Moving mass (Mms) | ![]() | 12.5 g |
![]() | Mechanical resistance (Rms) | ![]() | 1.3 kg / s |
![]() | Mechanical overvoltage. (Qms) | ![]() | style = "font-family: Verdana; font-size: small;"> 1.98 |
![]() | Electrical overvoltage (Qes) | ![]() | 0.43 |
![]() | Fact. total surge (Qts) | ![]() | 0.35 |
![]() | Volume equ. (VAS) | ![]() | 48 l |
![]() | DC resistance. (Re) | ![]() | 5.7 Ω |
![]() | ![]() | 0.5 mH | |
![]() | Coil diameter | ![]() | 25 mm |
![]() | Coil holder | ![]() | Alu |
![]() | Height winding | ![]() | 10 mm |
![]() | Air gap height | ![]() | 6 mm |
![]() | Linear Excursion (X MAX ) | ![]() | ± 2 mm |
![]() | Transmitting surface (Sd) | ![]() | style = "font-family: Verdana; font-size: small;"> 137 cm 2 |
![]() | Flight. air displaced (Vd) | ![]() | 27.4 cm 3 |
Force factor (BxL) | ![]() | 6 Tm | |
![]() | Ref. (No) | ![]() | 0.4% |
![]() | Magnet diameter | ![]() | 84 mm |
![]() | ![]() | 12.5 oz. | |
![]() | cutting | ![]() | Ø 162 mm |
![]() | style = "font-family: Verdana; font-size: small;"> ![]() | ||
![]() | Mounting depth | ![]() | 70 mm |
![]() | Dimensions | ![]() | 177 x 177 mm |
![]() | Weight | ![]() | 1.2 kg |
mg src = "http://www.monacor.com/global_img/blank.gif" alt = "" width = "10" height = "1" /> | Recommended Min Volume | ![]() | |
![]() | closed | ![]() | 16 l |
yl = "font-family: Verdana; font-size: small;"> ![]() | ![]() | ||
![]() | bass reflex | ![]() | 35 l |
