High Purity Silver Plated OFC Copper Wiring Cable PTFE Sleeve 0.5mm² Ø 3mm Transparent
This cable wire incorporates a high-purity OFC Copper conductor with a cross-section of 0.5mm² with Silver plating, ensuring excellent conductivity while being resistant to oxidation.
Reference : 13492
2,90 €tax incl.
2,42 € tax excl.
Câble au mètre
Fil de câblage
Fil de Câblage Cuivre OFC Haute Pureté Plaquage Argent Gaine PTFE 0.5mm² Ø 3mm
This cable wire incorporates a high-purity OFC Copper conductor with a cross-section of 0.5mm² with Silver plating, ensuring excellent conductivity while being resistant to oxidation. The conductor is covered with a transparent PTFE insulating sheath for an external diameter of 3mm. This cable will allow you to carry out the internal wiring of your DIY devices and projects.
Product typeWiring cable
Conductor materialOFC Copper
Conductor section0.5mm²
Conductor platingSilver
Sleeve materialPTFE
Cable diameter3mm
Min / Max temperature-65°C / +200°C
Sleeve colorTransparent
QuantitySold per meter
Diameter (mm)3.0
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)0.50
Ground / ShieldingNo
This cable wire incorporates a high-purity OFC Copper conductor with a cross-section of 0.5mm² with Silver plating, ensuring excellent...
