FURUTECH E-TP609E NCF Power Distributor NCF 6 Schuko Sockets
15%
The E-TP609E NCF is a sophisticated and luxurious sector distributor mounted in an Aluminium chassis. It eliminates many of the problems frequently found with audio and video components caused by a contaminated electrical signal.
Reduced price!
Reference : 13641
Limited time offer:
2 079,00 €tax incl.
-15%
1 767,15 €tax incl.
1 472,63 € tax excl.
Last items in stock !
Shipping date: 10-07-2025.
Furutech E-TP609E NCF
FURUTECH E-TP609E NCF Distributeur Secteur NCF 6 Prises Schuko
The E-TP609E NCF is a sophisticated and luxurious sector distributor mounted in an Aluminium chassis. It eliminates many of the problems frequently found with audio and video components caused by a contaminated electrical signal. The AC sinusoidal signal is subject to ground noise distortion, voltage spikes and drops, and interference from other electrical devices. In addition, the AC electrical circuit is shared with other adjacent dwellings, also involving distortion.
This E-TP609E NCF mains distributor makes it possible to limit these interference and distortion problems very considerably. It thus makes it possible to find a clean electrical signal and consequently a more precise restitution of high frequencies and midrange as well as controlled and aerated bass.
Nano Crystal² Formula (NCF)
Integrated into a selection of Furutech products, NCF incorporates a special crystalline material with two active properties. First, the NCF generates negative ions that eliminate static electricity. Second, it converts thermal energy into infrared. Furutech combines this material with ceramic nanoparticles and carbon powder for their piezoelectric damping properties. Furutech thus obtains the optimal electrical and mechanical damping material.
Anti EMI / RFI Shielding
The Aluminium chassis acts as a shield to protect against RFI interference (radio interference) and the GC-303 Formula material blocks EMI interference (electromagnetic interference). The internal wiring of the power supply unit includes Alpha treated conductors (α) with a cross-section of 3.8mm², guaranteeing low resistance. Schuko GTX-D NCF(R) Rhodium-plated Copper connectors are wired to a high-end IEC FI-09 NCF(R) connector also made of Rhodium-plated Copper.
GC-303 Formula
The GC-303 Formula material is directly bonded to the lower part of the chassis, thus absorbing EMI interference. The E-TP609E NCF uses no other filtering method than the GC-303 Formula to keep AC resistance to a minimum and thus achieve a more dynamic sound reproduction by getting the most out of your audio system.
Axial Locking System
Furutech has developed a locking system to anchor each pair of holds to prevent oscillation and improve long-term stability. A special 3M material also isolates each pair of taps from the resonances. In addition, each of the axial locks is perfectly tightened at the factory to work perfectly with the 3M resonance control material.
Product typePower distributor
Sockets number6
Voltage / Current250V 10A
Schuko connectors models3x GTX-D NCF(R)
Schuko connectors conductorsNon magnetic pure Copper, Rhodium plated, Alpha (α) treatment
Schuko connectors body materialNylon / Fiberglass NCF with anti-resosnance nano-sized crystalline particles
Piezo Ceramic particules and Carbon powder damping material
Matériau coque des connecteurs SchukoPolycarbonate NCF avec nano particules anti résonances
Matériau d'amortissement piezo avec particules Céramique / Poudre de Carbone
IEC Connector model1x FI-09 NCF(R)
IEC Connector conductorsRhodium plated pure Copper, Alpha (α) treatment
IEC Connector body materialNylon / Fiberglass NCF with anti-resosnance nano-sized crystalline particles
Axial locking system-
GC-303 Formula material-
Internal wiringFurutech Alpha-22. 3.8mm² section.
Housing materialAluminium
Alpha treatment (α)All the conductors are Alpha α treated (Cryogenic and demagnetizing process).
Dimensions (without feet)266 x 130 x 56.5mm
Weight2.94kg
ColorSilver and Black
Number of sockets6
FilteringNo
The E-TP609E NCF is a sophisticated and luxurious sector distributor mounted in an Aluminium chassis. It eliminates many of the problems frequently...
