VIBORG VE80 Filtered Power Distributor 8 Schuko Sockets 3300W 15A Aluminium Gray
This filtered mains distributor Viborg VE80 has 8 Schuko sockets. Filtering provides a clean and stable current to supply your HiFi devices correctly and thus limit noise.
4.9 / 5
By buying this product you get 28 loyalty points
Reference : 14258
285,00 €tax incl.
237,50 € tax excl.
Shipping date: 07-04-2026.
Viborg VE80
Viborg VE80 Distributeur Secteur Filtré 8 Prises Schuko 3300W 15A Aluminium Gris
This filtered mains distributor Viborg VE80 has 8 Schuko sockets. Filtering provides a clean and stable current to supply your HiFi devices correctly and thus limit noise. The power strip benefits from excellent manufacturing quality with a robust aluminum housing and an internal cable with OFC Copper conductors with a cross-section of 4mm². This power supply unit also has overload protection
Product typeFiltered power distributor
Number of filtered plugs8
Plug typeSchuko
Max. power3300W
Max. current15A
Internal wiringOFC Copper conductors 4mm²
Supply voltage220-250V 50Hz
ProtectionSurge protection
Case materialAluminium
Dimensions380 x 160 x 95mm
Weight3kg
ColorGray
Package1x Viborg VE80
1x Power cable
Number of sockets8
FilteringYes
13 reviews
Very useful and with surprisingly high value
Despite the different opinion in some comments, the design, the quality of the components and the construction and finally the sound performance are well above the asking price, even with the filter in place. The performance-price ratio is simply excellent and is mainly due to the quality of all the components used and the assembly which is well above the entry-level category. In terms of sound, expect an improvement across the spectrum, with a fuller and clearer low end, cleaner mids and highs and a more three-dimensional stereo image with clearer instrument contours. Perhaps the most important thing is that all of this happens without any noticeable penalty in dynamics which is the usual case even in some of the 2,000€ filters that I have tested. Highly recommend, especially at this price point. My system: Eversolo DMP-A8, AUDIOPHONICS HPA-DM750ET and AP300-S2503E (I prefer the later!!!), Focal Electra 1028 Be
This review has been posted for VIBORG VE80 Filtered Power Distributor 8 Schuko Sockets 3300W 15A Aluminium Gray
Belle boîte
Achetez uniquement pour le caisson et les embases, j'ai retiré le filtre, bypassé l'interrupteur et le fusible à réarmement et changé tout le câblage interne.
J'ai recâblé avec du OYAIDE EE / F-S2.0 V2 de3.3mm² et intégré un fitre SCHAFFNER protégé. Le résultat est au-delà de mes espérances tant la qualité est améliorée, mais comme toujours, la qualité du son est subjective pour chacun.
Je l'avais testé stock et j'ai été très déçu par rapport à ce que j'avais avant et ne regrette pas le tweak de ce distributeur.
Il revient au final plus cher de 160 euros, ce qui monte son coup à 400 euros avec le filtre et le câble, mais surpasse largement des distributeurs plus onéreux que j'ai pu posséder. Il faut aussi avoir envie de bricoler et il n'y a rien de compliqué, la grande difficulté réside dans le retrait des cosses sur l'interrupteur et le fusible car VIBORG a eu la bonne idée de les souder. Et pour finir, en suface il parait bien fini et propre, mais une fois démonté beaucoup de surprises sur la pietre qualité des éléments utilisés apparaissent, surtout dans un distributeur secteur ; bref tout est propre maintenant et ne m'en separerais pas de sitôt.
Même sans modification il vaut son prix, sauf le filtre qui est juste bon à jeter.
excellent rqp
Ce distributeur secteur dispose d'une qualité de fabrication indéniable ; boitier en métal brossé de forte épaisseur et de bonne finition ; prise iec d'entrée en cuivre . Au niveau du son un gain très significatif en netteté et propreté d'image . j'ai rajouté mes filtres quiet line + des pieds antivibratoires sur roulement à bille ( en vente sur ce site) ( gain d'aération de la scène sonore ) . Ce distributeur est une excellente base pour un prix plus que raisonnable , certains plus chers ne feront pas forcément mieux .
 (3)
Très bon produit, conforme aux avis. Niveau son bien mieux que le Bada 5600.
Jamais déçu par toutes les commandes passées.
Good, once stripped
Not good with all that’s inside…
I removed filter, fuse and on/off.
The frame is amazing robust, the inlets of high quality and it’s heavy enough to hold big power cords; and that’s why I bought it for.
Re-wire in star-wiring with wire of your choice and you have an amazing (also looking) power distributor!
 (3)
This filtered mains distributor Viborg VE80 has 8 Schuko sockets. Filtering provides a clean and stable current to supply your HiFi devices...
