MUNDORF MCAP EVO SILVERGOLD OIL Capacitor 650V 0.1μF
Reference : 7650
26,90 €tax incl.
22,42 € tax excl.
Shipping date: 02-09-2025.
Mundorf MCAP EVO SilverGold Oil
EVO Mcap by Mundorf is designed to ofeer tremendous audio precision at affordable price with low space-consumption. It fills every condition to offer a great sound restitution with rich and deep audio details.
Its polypropylene film (PP) is metallized with a layer of aluminum as thick as possible and formed following a proprietary geometry (Evolution Winding). The coil is then hand-poted in a audio shell order to reduce vibrations.
All these features contribute to a very lively audio reproduction that deeply respects microdynamics and stereophony. The whole EVO series is compliant to the highest standards of safety (self-healing).
Rigid wires for connections are made from gold-plated copper. They are long enough to allow vertical or horizontal mounting. Note that the shorter tab indicates the outer sheet of the capacitor.
This model belongs to the EVO Oil range introducing an oil impregnation step of the polypropylene (PP) films before building the coil. This maneuver removes residual air bubbles with formidable efficiency, which drastically reduces the electrical and mechanical losses associated with vibrations.
Dimensions
Condensateur Mcap EVO
TypeMcap EVO Silver Oil Capacitor
Capacity0.1 µF
Voltage650V
Tolerance±5%
Diameter12 mm
Length12
Wire diameter0,6
Wire A length35
Wire B length35
Temperature max-25°C / +125°C
DielectricPolypropylene (PP)
MetallisationAluminim
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)5
Capacitor capacitance (µF)0.1
Rated voltage (V)650.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Fabuleux
J'ai utilisé ce condensateur dans une liaison numérique avant un transfo de sortie ,en lieu et place d'un modèle déjà de qualité (MKP) et bien tout est devenu plus doux mais attention sans perte de définition, fluidité et naturel, voila...
This review has been posted for MUNDORF MCAP EVO SILVERGOLD OIL Capacitor 650V 0.1μF
