En complement a mon avis précédent :
Le digione donnera son meilleur avec une alimentation régulée. J utilise l audiophonics .l amélioration est tres sensible. Je n ai pas encore testé avec une batterie.
By buying this product you get 35 loyalty points
High performance digital network drive
sq.jpg)
This element is a digital player with network support. That is to say it is capable of playing audio tracks from a remote source. This source may be a hard drive located within the network or even an online streaming service.
Without any screen nor interface, Digione reader is controlled remotely with a mobile phone, tablet or any device capable of running a web browser. One can therefore enjoy a high quality audio playback without having to leave the couch or the bath.
The Allo Digione interfaces are currently the best digital SPDIF outputs to Raspberry Pi. They connect directly to a Raspberry Pi by GPIO and provide digital transfer while correcting jitter characteristic of a bare SBC.
This interface provides a BNC 75 Ohm output and RCA Coaxial Digital 24bit 192khz output. The rise time is 1 ns and the voltage completely meets the coaxial / BNC standards (550mV coaxial). This interface is capable of transforming a limited digital source such as Raspberry Pi into a true high-fidelity device with a remarkably low jitter of 400fs.
This is the latest version SIGNATURE Digione. The latter is divided into two parts isolated from each other (galvanic) operated with two power supplies to optimize the audio signal and avoid any pollution of the digital streams. It gets latest version of the NDK oscilateurs ultra low jitter noise . The audio circuitry also hosts a supercapacitor.
This modernized version of the player operates a SBC (single board computer / mini computer) Raspberry Pi release 3B +. This mini computer and audio platform retains all its qualities and even gaining performance through an extensive network connectivity (WiFi 802.11b / g / n / ac and 300mbps Ethernet).
Despite its small size, this device has every capability to play audio files of high quality, including the most demanding audiophile formats in terms of computing power and memory. This modernized version benefits in addition to improved stability and access to the fastest network.
.jpg)
Used in high fidelity chain, this type of network drive is extremely convenient since it is much more compact than a conventional computer and thus limits the space occupied. Wireless connectivity is also useful for the purpose of reducing congestion related to the accumulation of cables. Conversely, all of the computing power and its IT construction are mobilized in the service of audio quality. The sound quality will be multiplied compared to a smartphone or tablet classic.
So your devices dedicated to communication and work to avoid being solicités precarious audio use and are available for their other functions over the phone ringing in the middle of an opera or a computer that is updated during a guitar solo. The network drive for its part fulfills an audio function and will have no excuse to disturb listening.
Unlike many network drives based on an SBC kind Raspberry Pi, this Digione drive is already equipped with a preinstalled audio software. It is not necessary to have expertise in installing Linux or micro-SD card flash. The device is ready for use, it will only connect to your network to enjoy the full extent of its capabilities.
Volumio is a software developed in an effort to provide a high-performance audio interface while remaining as comfortable and intuitive point of view to use than any mainstream solution. This software exploits all the hardware capabilities of the Raspberry Pi, particularly its connectivity since it offers the possibility of controlling the drive from any device capable of connecting to a web browser (computer, smartphone, tablet or even another SBC ... etc). It is very simple to select music, change playback options, the volume from anywhere as long as the connection to the network exists.
To go even further and expand device capabilities, Volumio is also able to handle a wifi hotspot. That is to say, to establish an ad hoc network if fixed network is lacking. This means firstly that the device will still play your audio library even if your router / box fails. On the other hand, it also means that the network drive can be moved for use in private network places (spouse benefit to its small size).
The tradition of the SBC is particularly articulated around the concept of open source. Devices and software solutions compatible with Raspberry Pi are no exception to the rule so you can easily change the software installed on your network drive if you happen to wish to experience other softwares or other functions.
This network drive will work just as well with Max2Play, DietPi or Picoreplayer suit your audio projects. It will suffice to extract the micro-SD card and flash the firmware image with your choice.
| Specifications | |
| Type | Network Player |
| Version Raspberry Pi | 3B + |
| Processor | Broadcom BCM2837B0 4 hearts 1.4 Ghz |
| memory | 1GB |
| ports | Materialized: 4x USB / RJ45 1x / 1x HDMI Dematerialized: Wifi 802.11 b / g / n / ac / Bluetooth 4.2 |
| GPU | VideoCore IV |
| digital interface | Allo Digione SIGNATURE |
| Exits | S / PDIF Coaxial BNC & |
| galvanic isolation | Yes |
| Noise | 50uV |
| oscillators | 2x NDK |
| jitter | minimal 400fs |
| Power Supply | 5V (PI) 5-6V (Digione Signature) 100ma Min 2 power supplies are required Only the DigiOne Signature's power supply is provided. The power supply for Raspberry Pi is to be purchased separately |
| Housing | Acrylic |
| Accessories | Card 8GB e.MMC |
| Parts supplied | |
| Raspberry Pi | x1 |
| Digione Signature | x1 |
| Black acrylic Case | x1 |
| 8GB microSD | x1 |
| 5V power supply | x1 |
| DC cable - USB-C | x2 |
| Input | USB |
| Input | Micro SD |
| Input | Bluetooth |
| Input | RJ45 |
| Output | BNC |
| Output | Coaxial SPDIF |
| Max sampling rate | 192kHz |
| Color | Black |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
JACQUES M.
JACQUES M.
Michel C.
Istvan D.
Nicolas I.
