AURALIC VEGA S1 Streamer DAC Preamplifier
The Auralic Vega S1 is a full-featured, high-end Hi-Fi device capable of performing a variety of functions as a network player, DAC and preamplifier. Its integrated proprietary “Fusion” DAC and analog preamplifier stage enable it to be directly coupled to a power amplifier to get the best out of your music source.
By buying this product you get 199 loyalty points
Reference : 20093
1 999,00 €tax incl.
1 665,83 € tax excl.
Auralic Vega S1 Streamer DAC Preamplifier UPnP DLNA Roon Ready Airplay 32bit 384kHz DSD512
Photo of AURALIC VEGA S1
The Auralic Vega S1 is a full-featured, high-end Hi-Fi device capable of performing a variety of functions asstreamer, DAC and preamplifier. Its integrated proprietary Fusion DAC and analog preamplifier stage enable it to be directly coupled to a power amplifier to get the best out of your music source. The custom converter, based on Delta-Sigma and R2R technologies, can handle sampling rates up to PCM 32bit 384kHz and native DSD512.
This network player benefits from a Tesla G3 processor coupled with DMA (Direct Memory Access) technology. It provides access to streaming services such as Amazon Music, Qobuz, Tidal and Spotify, and is Roon Ready certified for intuitive, convenient access to files hosted on a local network. Additional functions such as tone control, CD ripping via USB and a beautiful color display will bring great satisfaction to every user.
Furthermore, the Auralic Vega S1's connector interface offers a wealth of possibilities. Inputs include a USB-B input, a coaxial SPDIF input, two Toslink optical inputs, and a USB-A port (USB Host). Signal output is via balanced XLR or single-ended RCA.
AURALIC VEGA S1 highlights
Auralic Vega S1: high-performance network player
The functionalities of the Vega S1 network player are based on the Tesla G3 platform, featuring a Quad-core 64bit processor with 2GB of memory and Direct Access Memory (DMA) technology for a considerable reduction in jitter and latency when the various components of the Vega S1 need to access its memory. This network player, which supports UPnP and DLNA protocols, not only provides access to a local network, but also to numerous streaming platforms: Amazon music, Qobuz, Tidal, Spotify, TuneIn. It also works with Airplay and is Roon Ready certified.
Photo of Tesla 3G processor
Auralic Vega S1: Fusion DAC
Auralic's proprietary Fusion DAC combines the best of the R2R and Delta Sigma discrete DACs. Fusion DAC consists in part of bypassing certain functionalities of a manufacturer's high-performance DAC chip by developing its own technologies. This allows only the DAC chip to be used for the final conversion process, for unrivalled sound quality.
Photo of the AURALIC VEGA S1 dac
Auralic Vega S1: R2R preamplifier and volume control
The Vega S1 features a Class A ORFEO preamplifier module, allowing the Vega S1 to be directly coupled to a power amplifier. However, the preamplifier function can be deactivated by Software to lower the output level to 2V and couple the device to another preamplifier. In addition, R2R volume control via a resistor network incorporating 8 relays eliminates noise and distortion when volume is changed.
R2R preamplification and volume control system
Auralic Vega S1: advanced features
CD playback and ripping
The Vega S1 can read and rip a CD at the same time, or simply perform one of the two operations. Metadata is directly recognized, whether for ripping or simple playback.
Pure DAC mode
Pure DAC mode
Pure DAC mode allows you to disable the functionality of the network player section, allowing all power to be used for digital-to-analog conversion. This function also enables you to use the DDR (Direct Data Recording) function to record the last hour of playback directly into the Tesla G3 system.
Tone and filter adjustment
Tone adjustment and filters
Several filters and a tone control allow you to adjust the sound rendering and give it a specific character according to the user's taste or the style of music being played.
Auralic Vega S1: Lightling DS App
The Vega S1 can be controlled remotely using Auralic's proprietary Lightning DS application. This iOS-exclusive app lets you play your music from multiple sources, including local files, simply, thanks to an elegant, ergonomic interface.
Auralic Lightning DS app Auralic Lightling DS
Auralic Vega S1 overview
Overview of Auralic VEGA S1
1Control buttons
2Display
3Balanced XLR output
4RCA output
52x Toslink optical input
6SPDIF coaxial input
7USB-B input
8USB-A port (HDD)
9LAN port
10HDMI connector for external PSU
11Power switch
12IEC power supply
Product typeStreamer / DAC
ArchitectureAuralic Tesla G3 (64bit, 2GO)
Volume controlR2R resistance network
Power supplyDual linear power supply
ClockFemtosecond 60fs
Inputs1x USB-B
1x Coaxial
2x Optical Toslink
1x USB-A port (USB Host)
Outputs1x Single-ended RCA
1x Balanced XLR
Other connectorsHDMI connector for external PSU
Supported sample ratesPCM up to 32bit 384kHz, Native DSD up to DSD512
Up-sampling: 32bit 768kHz
File formats supported (streaming)Lossless: AIFF, ALAC, APE, DIFF, DSF, FLAC, OGG, WAV and WV
Lossy: AAC, MP3 and WMA
Supported network protocolsRJ45 ethernet wired network
Airplay 2
UPnP/DLNA
Roon Ready
Open Home
Streaming servicesQobuz, Tidal, Tidal Connect, Amazon Music, Spotify connect, Online Radio
Qobuz connect with latest Auralic firmware
DisplayHigh-definition Retina display (300ppi retina, 3.97"), high contrast and anti-glare
AppAuralic Lightning DS for iOS
Auralic Lightning DS for web browser (device settings only)
OpenHome-compatible control software (BubbleUPnP, Kazoo)
Roon (Roon Core required separately)
Single-ended RCA output
Output level2V / 6V
Output impedance50 Ohm
Frequency response20-20KHz, +/-0.1dB
THD+N< 0.00015%
Dynamic range130dB
Balanced XLR output
Output level2V / 6V
Output impedance5 Ohm
THD+N< 0.00012%
Dynamic range130dB
Power supply240V AC
Power consumptionStandby : < 5W
On : <15W
Operating : 30W max.
Dimensions20.7 x 29 x 8.5cm
Weight4kg
Package1x Auralic Vega S1
1x Power supply cable
InputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate384kHz
Max sampling rateDSD512
NetworkingYes
Remote ControlYes
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
AURALIC VEGA S1 Streamer DAC Preamplifier UPnP DLNA Roon Ready Airplay 32bit 384kHz DSD512
The Auralic Vega S1 is a full-featured, high-end Hi-Fi device capable of performing a variety of functions as a network player, DAC and...
