FIIO S15 Streamer Preamplifier DAC Silver
With its S15, FiiO unveils a very high-quality audio streamer. In fact, it rivals many high-end streamers for a price that defies all competition. Ultra-complete, this device offers numerous streaming solutions thanks to its Android 12 operating system, while relying on a combo of AK4191EQ + AK4499EX DAC chips for top-level audio performance. It supports sampling rates up to PCM 32bit 768kHz and DSD512. It can also act as a preamplifier on its RCA and XLR line outputs. Thanks to its attractive color touch screen and operating system, it provides access to various streaming services such as Qobuz, Tidal, Amazon Music and Spotify.
By buying this product you get 109 loyalty points
Reference : 20398
1 090,00 €tax incl.
908,33 € tax excl.
FiiO S15 Streamer Preamplifier DAC AK4191EQ+AK4499EX WiFi Bluetooth Airplay DLNA Roon 32bit 768kHz DSD512 Silver
FiiO S15 picture
It also features Bluetooth 5.1 with a Qualcomm QCC5125 chip and compatibility with DNLA, Airplay and Roon protocols. In terms of connectivity, it's not to be outdone, with a USB-C input, an HDMI input, TOSLINK optical and SPDIF coaxial input/outputs, as well as RCA and XLR line outputs.
FiiO S15 highlights
FiiO S15: A streamer with a high-performance chipset
AK4191EQ+AK4499EX
AK4191EQ + AK4499EX
This DAC chip combo separates analog and digital signal processing for the most accurate sound reproduction. An XMOS V16AOP controller and timers ensure smooth operation.
XMOS XU-316
XMOS XU-316
This high-performance, low-latency chip offers a high level of compatibility and supports high-resolution streams up to PCM 32bit 768kHz.
Qualcomm QCC5125
Qualcomm QCC5125
This Bluetooth chip enables the S15 to process high-definition codecs such as aptX and LDAC. Moreover, the bi-directional function lets you send a stream to Bluetooth headphones or speakers.
Qualcomm Snapdragon 660
A master chip, it enables the S15 to integrate the Android 12 operating system and ensure fluid navigation on its screen.
FiiO S15: A linear power supply
The FiiO S15 streamer features an ultra-low-noise 35W linear power supply to power all its audiophile components. This power supply is furthermore coupled with four Elna 4700µF capacitors to ensure high current capacity. It's also worth noting that each stage of the network player is isolated for protection against interference and improved dynamics for clear, pure sound reproduction.
FiiO S15 power supply
FiiO S15: Fully balanced analog architecture
The analog circuitry of the FiiO S15 benefits from a fully balanced architecture from the DAC to the preamplifier stage. This considerably reduces noise and delivers a pure signal to the streamer's outputs. The outputs also feature both fixed and variable levels, allowing the S15 to be used as a preamplifier. In fact, the analog output stage is based on OPA1612, ensuring high voltage levels and good dynamics.
S15 analog circuit architecture
FiiO S15: a large color touch screen
The FiiO S15 features a large color touchscreen on its front panel. The Android 12 interface can be accessed via this for easy access to the various services. In addition, numerous interfaces are available, such as a vumeter, and the home screen is customizable.
The FiiO S15 screen
FiiO S15: A remote control app
An app lets you control the S15 remotely via your phone for the ultimate user experience.
Remote control via the S15's FiiO application
FiiO S15: 10-band equalization
A proprietary algorithm and interface provide the FiiO S15 with 10-band equalization, including gain, frequency, bandwidth and more. This function is available for all S15 operating modes, and can even simulate a specific frequency response.
FiiO S15 equalizer picture
FiiO S15: HDMI interface
The FiiO S15 supports HDMI 2.0 as input and is capable of outputting it as HDMI ARC or HDMI I2S via the two dedicated ports. This feature is very practical for anyone wishing to enjoy an immersive TV setup. The HDMI interface supports up to 24bit 192kHz and CD quality on the HDMI ARC output.
FiiO S15 HDMI interface
FiiO S15 overview
FiiO S15 overview
1Power/source selection
2Control buttons
3Display
4Play/Pause/Volume
5USB-A Host input
6USB-C DAC input
7SDD slot
8LAN port
9USB-A Host input
10USB-C input
11SD card
12HDMI input
13HDMI ARC output
14HDMI I2S output
15Trigger out
16AES/EBU input
17AES/EBU output
18SPDIF coaxial / Toslink optical input
19SPDIF coaxial / Toslink optical output
202x stereo RCA line output
21Balanced XLR line output
22Ground
23Switch GND
24Power switch / Power supply port
Product typeAudio streamer
DAC
Preamplifier
DAC chipAK4191EQ + AK4499EX
USB interfaceXMOS XU-316
Bluetooth chipQCC5125
ProcessorQualcomm Snapdragon 660, 4GB RAM+64GB ROM
Operating systemAndroid 12
Inputs2x USB-C
2x USB-A Host
1x HDMI
1x AES/EBU
1x Optical Toslink
1x Coaxial
1x SSD slot + USB-C
1x SD card slot
WiFi
Bluetooth
Outputs2x Single-ended RCA
1x Balanced XLR
1x HDMI ARC
1x HDMI I2S
1x AES/EBU
1x Toslink optical
1x Coaxial
Bluetooth
Other connectorsTrigger out
Supported sampling ratesNative decoding: PCM 32bit 384kHz, DSD256
USB DAC: PCM 32bit 768kHz, DSD512
Coaxial and AES/EBU: 24bit 192kHz
Optical Toslink: 24bit 96kHz
HDMI input: 24Bit 192kHz
Supported sampling rates on digital outputsUSB Audio: 32bit 768kHz, DSD512 (support DoP/D2P/Native)
Coaxial: 24bit 384kHz, DSD128 (DoP/D2P)
Optical Toslink: 24bit 192kHz
AES/EBU: 24bit 384kHz, DSD128 (DoP/D2P)
HDMI: 24bit 192kHz
Preamplified output levelPreamp RCA: 4.5+4.5Vrms (1kHz @ 10K ohm)
Preamp XLR: 8.9+48.9Vrms (1kHz @ 10K ohm)
Line output levelRCA: 2.4+42.4Vrms (1kHz @ 10K ohm)
XLR: 4.8+4.8Vrms (1kHz @ 10K ohm)
Frequency response20Hz-70kHz (attenuation < 2.8dB)
SNR≥ 131dB (A-Wt)
Noise floorLO < 1.8uV (A-Wt)
THD+N< 0.00023% (1kHz/0dB @ 10k ohm)
Streaming services and protocols compatibilityDLNA
AirPlay
Amazon Music
Deezer
Qobuz
Roon / Roon Bridge / Roon Ready
Spotify
Spotify Connect
Tidal
Tidal Connect
Web radios
Power supplyAC 100-240V 50/60Hz
Dimensions430 x 274.5 x 89.5mm
Weight5.65kg
ColorSilver
Package1x FiiO S15 streamer
1x Bluetooth remote control
1x 3.5mm trigger jack cable
1x USB-C to USB-C cable
1x HDD cage M.2
1x HDD cage installation screwdriver
1x Power cable
InputAES/EBU
InputHDMI
InputSD Card
InputWiFi
OutputHDMI ARC
OutputOptical Toslink
OutputI2S LVDS via HDMI
OutputCoaxial SPDIF
DAC / ADC ChipAK4499EX
DAC / ADC ChipAK4191
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
ClassN/A
NetworkingYes
Remote ControlYes
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
FIIO S15 Streamer Preamplifier DAC AK4191EQ+AK4499EX WiFi Bluetooth Airplay DLNA Roon 32bit 768kHz DSD512 Silver
With its S15, FiiO unveils a very high-quality audio streamer. In fact, it rivals many high-end streamers for a price that defies all competition....
