Fantastic mediaplayer. Top plate is glass. Luxury feeling. Very convenient ( control via Bluetooth with HibyMusic app on android.
Alot of connections like Bluetooth, Spdif coax and fiber optical and I2S.
By buying this product you get 41 loyalty points
Streamer WiFi DLNA AirPlay Bluetooth 32bit 384kHz DSD256 MQA
SMSL's SD-9 is an affordable and versatile network drive. It supports indeed many file formats and has a complete connectivity. The wireless transmission can be done in Bluetooth or in WiFi (DLNA / AirPlay).
The SD-9 adopts an architecture based on an ARM SoC and CPLD couple. The SoC takes care of the data decoding, while the CPLD takes care of the clock management of the audio signal. The clock signal is generated by two oscillators (22.5792MHz and 24.576MHz) in order to drastically reduce the jitter level and offer a very accurate sound reproduction.
The SMSL SD-9 is able to decode and play MQA (Master Quality Authenticated) files. These files allow to reach a sound quality as close as possible to the studio recording.
The SD-9 benefits from both wireless transmission via Bluetooth 4.0 and WiFi. It also supports DLNA and Apple AirPlay protocols for optimal compatibility with your other devices.
The SD-9 will be able to connect very simply to the HiBy Link mobile application. This one will allow you, via a neat and intuitive graphical interface, to manage the playback of your music remotely. Moreover, it will allow you to access the TIDAL streaming service, which offers files in MQA format for a high quality sound reproduction.
The SMSL network player is equipped with a particularly complete connectic to adapt to all the needs and all the audio systems. We can find in input USB-B (USB Audio), two USB-A connectors to connect storage devices, a slot for Micro SD card and an Ethernet RJ45 connector for a wired network connection. For its outputs, the SD-9 offers Toslink Optical, AES/EBU, Coaxial and I2S LVDS via HDMI.
1 | Power connector 100-240V 50-60Hz |
2 | Ethernet RJ45 |
3 | USB-A input (USB Host) |
4 | Optical Toslink output |
5 | USB-B input (USB Audio) |
6 | AES/EBU output |
7 | Coaxial output |
8 | I2S LVDS output via HDMI |
9 | Bluetooth antenna |
10 | Slot Micro SD |
Product type | Streamer |
Inputs | 2x USB-A (USB Host) 1x USB-B (USB Audio) 1x Micro SD slot Bluetooth WiFi 1x Ethernet RJ45 |
Outputs | 1x Optical Toslink 1x Coaxial 1x AES Bluetooth 1x USB I2S LVDS via HDMI |
Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
Max Micro SD card capacity | 256Go (not included) |
Max storage drive capacity | 4TB |
Max USB output current | 2A |
DAC output function | |
Bluetooth version | 4.0 |
Supported Bluetooth codec | aptX |
HiBy Link compatibility | |
WiFi bandwidth | 2.4G/5G |
Dimensions | 187.4 x 154.5 x 42mm |
Operating consumption | 2W |
Standby consumption | 0.5W |
Input | USB |
Input | Micro SD |
Input | WiFi |
Input | Bluetooth |
Input | RJ45 |
Output | USB |
Output | I2S LVDS via HDMI |
Output | Bluetooth |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Output | AES/EBU |
DAC / ADC Chip | NC |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Black |
Remote Control | Yes |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | AirPlay |
Average votes 4.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
David D.
Pascal p.
