AUDIOPHONICS RASPDAC LTE I-SABRE V4 Streamer Raspberry Pi 3 B+ & DAC TCXO
This RaspDAC LTE network drive is based on a Raspberry Pi 3 B+ and a DAC I-Sabre V4 ES9023 TCXO. It will allow you to enjoy your digital library simply and in high definition.
By buying this product you get 22 loyalty points
Reference : 11594
229,00 €tax incl.
190,83 € tax excl.
AUDIOPHONICS RASPDAC LTE V4
DAC network player Audiophonics I-Sabre V4 ES9023 TCXO and Raspberry Pi 3 B+
RaspDAC LTE
Go to the high definition dematerialized with the RaspDac LTE. Housing 100% Aluminum, DAC ES9023 24bit / 192Khz TCXO, Raspberry 3 B+ !
Here is the first affordable solution of dematerialized reading assembled and tested in our workshops.
Ready-to-use network reader electronically, you just have to choose the software solution of your choice (Max2Play, OSMC, piCorePlayer ...).
A high-end audio player ...
Simply get a high-end digital audio player with a 24bit / 192kHz Bit-Perfect resolution.
Optimized for the sole purpose of offering maximum music, Audiophonics integrates the new DAC I-Sabre v4 ES9023 24 / 192Khz equipped with a TCXO precision clock as well as a revised and corrected mass circuit, a new low noise regulation LDO capacitors OS Con the DAC I-Sabre v4 is the heart of the RaspDAC LTE.
In addition, its advanced ATX-type power management with different possible shutdown modes offers a high level of ease of use.
This V2 model now has two offsets: one for the HDMI and one for the micro SD card. This allows the RaspDAC LTE to offer even more integration possibilities in any audio system.
Your Raspberry Pi in a high quality Audio environment.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi 3 B+ in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a high-performance audio solution and achieved excellent value for money.
Raspberry Pi 3Model B+
DACAudiophonics I-Sabre v4 ES9023 TCXO
inputs1 x RJ45 / 4x USB-A / 1x Micro SD
Exits1x RCA Stereo / 1x HDMI
FoodJack DC 5.5 / 2.1mm
Dimensions102 x 169 x 58mm
Weight0.65kg
Housing material100% Aluminum
Aluminum Case for DAC Audiophonics & Raspberry Pi 3 B+
This 100% Aluminum case designed in our workshops receives the Raspberry Pi 3 B+ & DAC Audiophonics I-Sabre v4 ES9023 TCXO or DAC I-TDA1387 TCXO.
RaspDAC housing
Supplied accessories:
To enable you to be directly operational, the player comes with an external standard 7V 2A power supply on 5.5 / 2.1 connector.
InputRJ45
InputMicro SD
OutputHDMI
DAC / ADC ChipES9023
Max sampling rate192kHz
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
This RaspDAC LTE network drive is based on a Raspberry Pi 3 B+ and a DAC I-Sabre V4 ES9023 TCXO. It will allow you to enjoy your digital library...
