RASPTOUCH I-SABRE ES9038Q2M KALI Streamer Touchscreen with Volume Control
Discover the latest version of the ES9038Q2M Rasptouch network player from Audiophonics. Enhanced version incorporating the latest Rapsberry Pi 4+ for great stability and connectivity with the I-SABRE ES9038Q2M card and Allo Kali reclocker.
4.7 / 5
By buying this product you get 54 loyalty points
Reference : 12249
549,00 €tax incl.
457,50 € tax excl.
RASPTOUCH ES9038Q2M KALI EDITION
HIFI Streamer with DAC ES9038Q2M with RECLOCKER ALLO KALI and volume / source controller
Rasptouch Front View with 7-inch touch screen
The concept
Audiophonic's RaspTouch is a simple and effective hardware solution combining both network drive and DAC with reclocker. The device offers exceptional audio quality due to high level Digital / Analog conversion based on ES9038Q2M and Allo Kali reclocker.
The RaspTouch lets you enjoy your favorite music while controlling playback from its 7 "touch screen, smartphone or even your PC. The PCB dedicated to playing audio file works with a SBC (Single Board Computer) Raspberry Pi 4 B . This circuit is the reference area and the most powerful model offered by the brand.
With its large screen and wide audio connectivity, RaspTouch combines ergonomics and smoothness of sound reproduction for increased music enjoyment.
Warning: this version does not support DSD
The DAC
Internal view Rasptouch Audiophonics
For this version of RaspTouch, Audiophonics integrates the excellent ES9038Q2M converter supporting sampling rates up to 384kHz 32bit. It integrates a high precision 100MHz clock, low noise LDO regulator, an ultra-low noise regulator (9μV) for the reference voltage of the chip and an ESS Altera processor.
This DAC uses HyperStream 32bit technology with a wider dynamic range while drastically reducing jitter. With this design, ES9038Q2M displays a dynamic range of 129dB and THD + N of -120dB to offer new musical horizons.
32-bit attenuation technology enables lossless volume control and direct use without preamp. This hardware volume control is controllable from Raspberry through diponible dedicated driver in our Image Volumio or under Dietpi.
With an integrated microprocessor, the DAC is capable of automatically detecting the format and sample rate source and adapt automatically. It thus automatically detects if the source is 16bit / 24bit remaining bitperfect. This control by CPLD chip maintains high stability while preventing decoding problems as well as audible artifacts apparation.
It is compatible with formats up to 384kHz on its 2 inputs. It embeds two bipolar operational amplifiers NJM 2114 9V fed to the converting section current / voltage I / V, which allows a large analog output quality. A final PDO NJM 2214 used buffer completes the analog output stage and ensures optimum return.
Reclocker KALI ALLO
Connections neat practical design DAC hi fi audio player
In addition to the excellent DAC ES9038Q2M the Rasptouch Kali release includes a high performance reclocker KALI developed by ALLO. Thanks to its dual clock 44/48 MHz erasing inaccuracies related to the internal clocks of the Raspberry Pi 4 B, the Reclocker greatly increases the device's performance in terms of accuracy & clock noise.
The Rasptouch KALI EDITION and offers sound quality equivalent to the best streamers audiophile market.
The connection
Connection Rasptouch Kali
The RaspDAC offers full connectivity let you enjoy your audio system and it very simply. We find the connections of Raspberry Pi 4 B with 4-port USB-A 2.0, a Micro SD port, an Ethernet port and a remote HDMI output. On the USB ports you can connect all kinds of compatible devices:
  • Hard Drive or USB Key
  • WiFi USB Key
  • USB external DAC
  • Keyboard / Mouse ...
    The DAC provides an analog output and a stereo RCA input SPDIF Coaxial. Power is supplied by a DC base 5.5 / 2.1mm connected to an integrated linear power supply allowing good stability. The maximum input voltage is 7 to 9 V DC and up to 12V maximum.
    The power button does not just turn off the power, but before launching system shutdown. It is also possible to switch it off from the interface of Volumio.
    Beware, despite the native WiFi connectivity Raspberry Pi 4 B, the latter was sacrificed to install the drive in an insulated aluminum housing disturbances. The wifi connection requires a USB on external adapter (Dongle Wifi) ..
the Software
Sofrtware Volumio for DAC Audiophonics
Announcing himself as a free system, the RaspTouch comes without operating system. This choice depends on your hardware, the ambition of the project and the expected functionality.
The device is ready as far as electronics are concerned, So it remains to choose an operating system and mount it on the provided micro-SD card. Many softwares are available to meet all your expectations: piCorePlayer, Max2Play, OpenELEC, Volumio ...
Depending on the software, you can access the following features:
- Complete Support and unlimited Multiroom
- Remote Play audio files stored on a media server connected to the network (NAS)
- Remote reading from a UPnP source.
- Playback from USB source (hard disk, USB key)
- DLNA Management
- Support Qobuz
- Support Airplay
The unit comes with an appropriate micro-SD card to install the operating system.
Connector : Inputs
USB-A 2.04x
Ethernet RJ451x
Micro SD Slot1x
Connector : Outputs
Stereo RCA1x
HDMI1x
Raspberry Pi 4
SoC Broadcom BCM2711
CPUARM Quad Core Cortex-A72 (ARM v8) 64bit SoC @ 1.5GHz
WifiNEEDS WIFI DONGLE
Bluetooth5.0
GPUCoprocessor multimedia IV Videocore dualcore
RAM2Gb LPDDR4
ES9038 / Allo Kali
Sampling rateUp to 32bit 768kHz
Dynamic range129dB
THD+N-120dB
Allo Kali 384kHzI2S FIFO Reclocker - 44/48MHz Clock
Display & Case
Primary display7" capacitive tactile screen 800 x 400px
Case materialAluminium
Power supplyJack DC 5.5/2.1mm - 7.5V 2.9A (included)
Dimensions200 x 95 x 230mm
Weight1410g
AccessoriesMicro SD Card / Power supply 7,5V 2,9A MEANWELL
InputRJ45
InputMicro SD
OutputHDMI
DAC / ADC ChipES9018
DAC / ADC ChipAK4396
DAC / ADC ChipWM8524
DAC / ADC ChipES9023
DAC / ADC ChipCS4344
DAC / ADC ChipAK4495SEQ
DAC / ADC ChipES9016
DAC / ADC ChipDSD1793
DAC / ADC ChipCM6533
DAC / ADC ChipCS4270
DAC / ADC ChipPCM1796
DAC / ADC ChipES9028PRO
DAC / ADC ChipES9038PRO
DAC / ADC ChipES9118C
DAC / ADC ChipES9218P
DAC / ADC ChipES9038Q2M
DAC / ADC ChipAK4399
DAC / ADC ChipES9018K2M
DAC / ADC ChipPCM1794
DAC / ADC ChipPCM2704
DAC / ADC ChipPCM2702
DAC / ADC ChipWM8741
DAC / ADC ChipAK4497EQ
DAC / ADC ChipAK4452
DAC / ADC ChipR2R LADDER DAC
DAC / ADC ChipAK4440
DAC / ADC ChipVT1620A
DAC / ADC ChipPCM1704UK
DAC / ADC ChipWM8805
DAC / ADC ChipES9026PRO
DAC / ADC ChipTenor 7022
DAC / ADC ChipAK4390EF
DAC / ADC ChipWolfson 8524G
DAC / ADC ChipAD1955
DAC / ADC ChipPCM5102
DAC / ADC ChipAK4490EQ
DAC / ADC ChipCS42L42
DAC / ADC ChipCS4398
DAC / ADC ChipES9028Q2M
DAC / ADC ChipWM8740
DAC / ADC ChipPCM1795
DAC / ADC ChipES9018Q2C
DAC / ADC ChipAK4137EQ
DAC / ADC ChipSabre 32
DAC / ADC ChipMS8413
DAC / ADC ChipCS5343
DAC / ADC ChipPCM1793
DAC / ADC ChipPCM1792A
Max sampling rate768kHz
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsTidal
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
7 reviews
Excellent
J'ai pris le temps (2 mois) pour donner ce commentaire
Ce Rasptouch est excellent ! Acheté pour remplacer une Squeeze Touch et pour améliorer un tant soit peu le son. Je ne suis pas puriste, mais exigeant pour mes oreilles.
J'ai été impressionné par sa restitution sonore et par l'équilibre qu'il apporte à l'écoute, et ce même avec du MP3 avec un échantillonnage '"moyen".
Le DAC est très très bon. Couplé avec un bon système HiFi, on arrive à ressentir la scène spatialement avec de bons enregistrements.
J'apprécie beaucoup cette intégration d'Audiophonics. Produit techniquement avancé et ouvert !
Je l'utilise avec Picoreplayer, préféré pour mon usage après essai des autres players. Deezer / LMS sur le PI donne l'autonomie que j'attendais avec une interface que je trouve plus lisible.
Tout est solide et équilibré. La gestion propre du bouton on/off est un détail non négligeable. Je n'en demande pas plus.
Je me surprends à utiliser plus que d'habitude mon système audio grâce (ou à cause ) de ce Rasptouch. C'est un vrai plaisir.
Merci au support Audiphonics pour sa disponibilité et sa réactivité.
This review has been posted for RASPTOUCH I-SABRE ES9038Q2M KALI Streamer Touchscreen with Volume Control
Excellent
Excellent lecteur réseau en tous points.
Fabrication :
Composants de qualité et un boitier beau et sobre. La qualité de fabrication et finition est bien présente. Le Rasptouch est agréable à manipuler et à regarder. Facile à assembler et démonter au besoin. Il y a de la place dans le boitier.
La finition est soignée et une impression de robustesse se dégage du Rasptouch malgré sa petite taille, qui est bien pratique ceci dit.
Un bémol concernant la face arrière dont la sérigraphie est bien trop fragile et s'efface facilement (trop facilement ?) en cas de frottement. Cependant la face arrière est... derrière... donc est-ce bien grave ?
Qualité sonore :
Du très bon, il se mari parfaitement avec mon ensemble hifi. Néanmoins, et c'est subjectif, l'écoute sans préampli est un peu froide et molle.
La musique parait claire et détaillée, mais ça encore c'est subjectif et dépend aussi de l'ensemble de la chaîne.
J'ai testé de nombreux appareils et le Rasptouch est excellent pour ce tarif. Il y a toujours mieux mais à quel prix ?
Il est important de préciser que j'ai l'alimentation dédiée fabriquée par Audiophonics qui apporte beaucoup. Sans cette alimentation, c'est toujours excellent mais moins aéré.
Logiciel :
Il y plusieurs solutions à installer sur le Rasptouch. J'en ai testé deux : Volumio et mOode.
Mon choix final s'est porté sur moOde. Il est moins intuitif que Volumio mais la restitution me paraît juste. Sur Volumio j'ai eu l'impression d'une restitution "étouffée".
Bref, il y a du choix et tout le monde y trouvera son compte. Le fait de pouvoir installer la solution de son choix est un vrai plus comparé à la concurrence.
Tout est contrôlable depuis n'importe quel appareil qui possède une connexion internet et un navigateur.
Fabrication 4.5/5 (face arrière à la sérigraphie fragile)
Qualité sonore : 5/5
Utilisation : 5/5
Très bonne machine!
Reçu il y a peu, j'ai installé ce Rasptouch facilement malgré mon peu de connaissances en informatique et dans le domaine de Raspberry, en suivant les tutos disponibles sur le site Audiophonics et Qobuz.
Une première installation avec picorepalyer v5.0.0 n'a pas correctement fonctionné (pas de prise en charge du bouton d'alimentation, interface capricieuse).
J'ai alors installé Max2Play (certains plugins sous licence, mais coût modique), tout fonctionne parfaitement bien.
Je l'utilise pour streamer Qobuz et les radios internet.
Avec mon installation (Marantz PM6006 et de vieilles enceintes Pierre Étienne Léon modifiées par les soins d'un proche connaisseur), le son est très bon, la restitution parfaite pour les enregistrements en haute définition (en tout cas me convient parfaitement !).
La machine démarre rapidement, le design s'intègre facilement dans mon installation.
À noter : la disponibilité de l'équipe d'Audiophonics qui a répondu rapidement à toutes mes nombreuses interrogations et m'a conforté dans mon achat.
À voir dans la durée, mais pour le moment, très satisfait de mon achat et de la qualité sonore offerte.
RaspTouch
Mein Traumgerät, war leider etwas enttäuscht da die MicroSD Verlängerung sehr schlecht bzw. im Gerät NICHT befestigt war, ich musste das ganze Gerät auseinander schrauben um es zu befestigen. Ja man muss auch solche Dinge ansprechen den für fast 600€ MUSS es PERFEKT sein.
Funktionieren tut es tadellos allerdings gibt es wohl keine passenden Treiber für den Max2Play Player, dort gibt es als Soundkarte leider nur den i-Sabre V3, damit funktioniert zwar der Ton aber nicht alles was im RaspTouch eingebaut ist. Leider....
Très bonne machine
Ce n'est pas du plug and play, l'installation du logiciel de lecture demande du temps et des recherches sur les blogs pour trouver les bons paramétrages. Une fois l'installation réussie, l'interface tactile est très pratique. le son est très bon, mais ne pardonne rien aux mauvais enregistrements. A recommander
Discover the latest version of the ES9038Q2M Rasptouch network player from Audiophonics. Enhanced version incorporating the latest Rapsberry Pi 4+...
