DAYTON AUDIO DSA115-PR Passive Radiator Aluminum 30.9Hz Ø10.2cm
The Dayton Audio DSA115-PR is a passive radiator that can be used in a wide variety of installations, whether as a speaker or as a replacement for a similar defective model. A built-in grounding disc ensures that the passive radiator will fit most applications, and an M5 thread allows you to add weight for a precise fit.
4.5 / 5
Reference : 14765
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 05-08-2025.
Grantie 5 ans
Radiateur Passif Aluminium 30.9Hz Ø10.2cm
Dayton Audio DSA115-PR Radiateur Passif Aluminium 30.9Hz Ø10.2cm
The Dayton Audio DSA115-PR is a passive radiator that can be used in a wide variety of installations, whether as a speaker or as a replacement for a similar defective model. A built-in grounding disc ensures that the passive radiator will fit most applications, and an M5 thread allows you to add weight for a precise fit. The aluminum diaphragm and rubber suspension allows for a long linear excursion, while providing true ruggedness for long life.
How a passive radiator works
The passive radiator (or passive loudspeaker) fits into a box with an active loudspeaker. This passive radiator, although it may at first glance look like a "classic" loudspeaker, does not in fact have any engine parts. Thus, its design does not include a coil, magnet and power supply. In the same way, it will not be electrically connected to a power amplifier.
To diffuse sound, the passive radiator will use the air pressures and depressions induced by the active loudspeaker in the cabinet to vibrate its diaphragm and restitute sound, thus providing deep bass. Its resonant frequency is determined by its mass and contained in the cabinet. Therefore, on many models, its resonance frequency can be varied and tuned to the speaker by adding mass.
Fonctionnement d'un radiateur passif
Product typePassive radiator
Nominal diameterØ10.2cm (4")
Resonant frequency (Fs)30.9Hz
Mechanical quality factor (Qms)3.48
Compliance equivalent volume (Vas)0.33 ft.³
Mechanical compliance of suspension (Cms)2.27mm/N
Diaphragm mass inc. airload (Mms)11.7g
Max. linear excursion (Xmax)6mm
Surface area of cone (Sd)54.1cm²
Material
ConeAluminum
SurroundRubber
FrameSteel
Mounting informations
Overall outside diameterØ11.56cm (4.55")
Cutout diameterØ9.4cm (3.69")
Depth3cm (1.17")
Bolt circle diameterØ10.7cm (4.21")
Number of mounting holes4
Weight159g
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)102.0
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
2 reviews
Renforce nettement les graves dans un caisson petit volume.
This review has been posted for DAYTON AUDIO DSA115-PR Passive Radiator Aluminum 30.9Hz Ø10.2cm
Radiateur passif
Radiateur passif très efficace pour des enceintes compactes. Simple possédant de belles finitions.
Astuce : pour accorder ce haut-parleur à l'enceinte, le monter à l'envers afin de modifier la masse vissée plus simplement.
The Dayton Audio DSA115-PR is a passive radiator that can be used in a wide variety of installations, whether as a speaker or as a replacement for...
