By buying this product you get 72 loyalty points
No featrued products
The Dynaudio EMIT 10 are compact two-way stand-mountable speakers. This model is therefore ideal for small to medium-sized rooms. They are equipped with a 14cm MSP (Magnesium Silicate polymer) bass/midrange woofer and a 28mm Cerotar tweeter. In terms of performance, they are capable of reproducing a powerful, rich and detailed sound. This pair of speakers offers great performance in both hi-fi and home theater configurations.
The EMIT 10 is equipped with a dual-magnet MSP driver for bass and midrange. This feature provides greater control and higher sensitivity. Thus, the MSP driver of the Dynaudio EMIT 10 provides a wide frequency response (52Hz - 35Khz) while ensuring a beautiful clarity on the midrange, all without distortion even at high volume.
The Cerotar tweeter of the EMIT 10 has a diameter of 28mm, larger than the usual tweeters. This soft dome model is made of fabric and a DSP coating (Dynaudio Secret Recipe). It allows a detailed and powerful reproduction of the treble, without generating hearing fatigue during long listening sessions. Moreover, the presence of the Hexis feature optimizing the air flow allows to keep a pure sound by limiting the distortions and the undesirable resonances while offering a more detailed sound.
Dynaudio has chosen to use two distinct circuits to reproduce the incoming sound signal. A first order filter for the high frequencies and a second order filter for the bass and midrange. This drastically improves the performance of the EMIT 10 in terms of sound reproduction. In addition, this feature allows you to combine the EMIT 10 with other models in the range while maintaining optimal tonal consistency.
On its rear face, the Dynaudio EMIT 10 have a screw terminal block allowing the speakers to receive 4mm banana plugs, spades or even stripped high-section cables.
These Dynaudio speakers benefit from a Bass-Reflex design. The speaker housing is made of 18mm thick MDF and come with magnetic grille. Many internal reinforcements are also present inside the housing as well as a damping coating eliminating interferences and vibrations.
| Specifications | |
| Product type | Bookshelf speakers |
| Number of ways | 2 |
| Bass Reflex | Facing backwards |
| Bass/Medium speaker diameter | Ø140mm |
| Tweeter diameter | Ø28mm |
| Frequency response | 52Hz - 35kHz (±6dB) |
| Nominal impedance | 6Ω |
| Sensitivity | 85dB (2.83V/1m) |
| Crossover frequency | 3700Hz |
| Crossover topology | Tweeter: 1st order filter Woofer: 2nd order filter |
| Power rating (IEC) | 150W |
| General | |
| Dimensions (W*D*H) | 170*271.5*290mm |
| Weight | 6.43kg |
| Color | Black |
| Color | Black |
| Impedance (Ω) | 6 |
| Efficiency / Sensitivity (dB) | 85.0 |
| Lowest frequency (Hz) | 52 |
| Highest frequency (Hz) | 35000 |
| Power (W) | 150.0 |
| Number of loudspeakers | 2 |
| Speaker type | Passive |
| Speaker form factor | Bookshelf speaker |
