DD TC35PRO MOUNTAIN2 Adapter Headphone Amplifier DAC USB-C CS43131 32bit 384kHz DSD256 MQA
This small DD TC35Pro Mountain2 adapter, designed primarily for use with a smartphone with USB-C connectivity only, features a male USB-C connector and a female 3.5mm jack port. It integrates both a DAC and a headphone amplifier.
Reference : 18243
65,90 €tax incl.
54,92 € tax excl.
Shipping date: 03-06-2025.
DD TC35Pro Mountain2 Adaptateur Amplificateur Casque DAC USB-C Jack 3.5mm CS41313 32bit 384kHz DSD256
This small DD TC35Pro Mountain2 adapter, designed primarily for use with smartphones with USB-C connectivity only, features a male USB-C connector and a female Jack 3.5mm port. It incorporates both a CS41313 DAC capable of decoding PCM streams up to 32bit 384kHz and DSD up to DSD256, as well as an amplification section with independent ES9603Q AOPs. This means you'll be able to enjoy superb listening quality with your smartphone. What's more, its aluminum casing makes it particularly robust, making it ideal for use on the move.
Product typeMale USB-C to female Jack 3.5mm adapter
Headphone amplifier
DAC
Connectors1* Male USB-C
1* Female Jack 3.5mm
DAC chipCS43131
OPAES9603Q
Output power2x65mW @ 32 Ohm
SNR> 122dB (A-wt)
Dynamic range> 120dB (A-wt)
THD< 0.0004% @ 1kHz
Frequency response20Hz-20kHz
Native DSD up to DSD256
LED indicatorBlue: PCM
Green: DSD
Shell materialAluminum
Dimensions (without contacts)28.5*17*10.4mm
Weight8.5g
ColorSilver
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateDSD256
ColorSilver
ConnecticMale & Female
ConnectorUSB-C
ConnectorJack 3.5mm
ClassN/A
Contacts Plating (Connector)N/A
This small DD TC35Pro Mountain2 adapter, designed primarily for use with a smartphone with USB-C connectivity only, features a male USB-C connector...
