DD TC44C Portable Balanced DAC 2x CS43131 Lightning 32bit 384kHz DSD256
The DD TC44C is an extremely compact but very powerful portable DAC, particularly suitable for association with a smartphone. It integrates a USB-C input and a dual output on single-ended 3.5mm jack and balanced 4.4mm jack. Taking advantage of a careful design oriented audio performance, its balanced digital / analog conversion circuit embeds a pair of Cirrus Logic CS43131 DAC chips ensuring a wide dynamic range, low distortion, and supporting high sampling rates, up to 32bit 384kHz PCM and DSD256 native.
Reference : 16311
139,00 €tax incl.
115,83 € tax excl.
DD TC44C
DD TC44C DAC Portable Symétrique 2x CS43131 USB-C 32bit 384kHz DSD256
The DD TC44C is an extremely compact but very powerful portable DAC, particularly suitable for association with a smartphone. It integrates a USB-C input and a dual output on single-ended 3.5mm jack and balanced 4.4mm jack. Taking advantage of a careful design oriented audio performance, its balanced digital / analog conversion circuit embeds a pair of Cirrus Logic CS43131 DAC chips ensuring a wide dynamic range, low distortion, and supporting high sampling rates, up to 32bit 384kHz PCM and DSD256 native. Its internal wiring is also optimized, using OCC copper conductors and silver solder (3%), ensuring excellent conductivity.
The TC44C also features a handy LED indicator, positioned around its 4.4mm jack connector, indicating the type of signal received: blue for a PCM stream, green for a DSD stream. The DAC comes with a high-quality MFi06S Lightning cable, featuring silver-plated OCC copper conductors and double PTFE / TPU insulation.
Product typePortable DAC
DAC Chip2x Cirrus Logic CS43131
Input1x USB-C
Outputs1x Balanced Jack 4.4mm
1x Single-ended Jack 3.5mm
Output power120mW (Jack 4.4mm)
SNR> 125dB
Dynamic range> 120dB
THD+N< -110dB
Native DSD up to DSD256
Internal wiring materialOCC Copper
LED IndicatorBlue : PCM signal
Green : Native DSD signal
Dimensions40.8 x 22 x 12.5mm
Weight12.9g
Package1x DD TC44C
1x MFi06S Lightning Cable (Silver plated OCC Copper)
1x Leather case
InputLightning
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateDSD256
ColorGray
SURPRISE
Pas d'attente partculière lors de la commande Sinon d'avoir un bac dongle qui gère mes câbles (IEM IE900 et MSR7b) au format symétrique 4.4. Excellente surprise DAC a signature très neutre avec superbe séparation et image, grave très tendu. Je le trouve supérieur à mon audioquest cobalt. L'achat du câble TS9 est fortement conseillé et amène une amélioration notable de la scène sonore et notamment la profondeur. Très beau médium aussi. Bref une sacrée surprise pour le prix. je l'utilise avec audirvana et mon iPhone (qobuz)
This review has been posted for DD TC44C Portable Balanced DAC 2x CS43131 Lightning 32bit 384kHz DSD256
The DD TC44C is an extremely compact but very powerful portable DAC, particularly suitable for association with a smartphone. It integrates a USB-C...
